my bandwidth speed
danger boy
I went to Cnet.com and checked my bandwidth speed. here are the results. where it says. YOU in red. that is my speed at home.
PolkFest 2012, who's going>?
Post edited by danger boy on
Heres mine, been wondering where another site to test bandwidth was..
edit: don't hit refresh to redo the test, it will increase your reading, use the back button and redo... I hit refresh after i did this test and it went to crazy speeds...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Mine was 3,445 kbps. (Cox internet cable).Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
would the speed of your connection also have to do with your RAM and processsor speed? more RAM and faster processor will increase your speed?
with two computer running WinXP
computer 1 1.7gig P4 and 512MB RAM
computer 2. 2.8gig AMD Athlon w/512MB RAM
will both have the same speed measured?
I know one can PROCESS faster than the other. but is the connection speed the same for this test?PolkFest 2012, who's going>?
danger boy- it really depends on how big the difference is. If you have too slow of a computer then it's probably not going to be able to handle all that traffic as efficiently as a faster one would. However, with your two computers, I don't think you'd see much of a difference.
FWIW, here's another speed test site- http://www.bandwidthplace.com/speedtest/
You can only run 3 tests per IP per month, but I like it because they have a number of servers around the country, not just in CA like DSLreports. Haven't tried the cnet test yet... will try now...Ludicrous gibs! -
Just to show you, I got 1332.5 from cnet, and 2.9mbit from bandwidthplace, within a minute of each other.
The reason speeds will go up if you refresh is because they actually use an image file to monitor the bandwidth. If you hit refresh, your computer already has that image file cached, so it reads it off your HD instead of off the internet...
give www.bandwidthplace.com/speedtest/ a shot... their servers appear to be less busy.. or at least closer to PA.
Ludicrous gibs! -
i didn't refresh on my test. it was a one time only test. early in the day without much traffic I would assume.PolkFest 2012, who's going>?
Life without music would♭
I was actually commenting on faster100's edit about refreshing.
Isn't broadband a wonderful thing, guys? I could never go back to dialup...Ludicrous gibs! -
thats where i usually test, bandwidthplace.com
I must have a pretty good pipe,
4.5 megabits per second
Communications 4.5 megabits per second
Storage 553.5 kilobytes per second
1MB file download 1.9 seconds
Subjective rating AwesomeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
3784.8 kbps cablevision optimum online
then i went and checked at badnwitdh place.com or whatever and look what i came up with
9.4 megabits per second
Communications 9.4 megabits per second
Storage 1.1 megabytes per second
1MB file download 0.9 seconds
Subjective rating Unbelievable -
www.pcpitstop.com report for my line at home:
Bandwidth Down 15065 Kbits/sec
Bandwidth Up 1863 Kbits/sec
Average Ping 4 ms
Ping Loss 0%
Real download times, for single download the best I got was from Ubisoft, 8Mbits/s. Multiple downloads from Fedora site, 18Mbits/s. The best part really is the upload, I can now share files.
Fiber is good, especially considering mine is $45 a month. -
Airplay- I thought that bandwidthplace.com was capped at 8mbit... guess yours snuck through. Either that, or something is skewed there... What's your line supposed to be? mines supposed to be 3.5mbit, so my 2.9 is pretty decent considering it's during the day and there are 3 other computers on right now.
Sami- You suck.Ludicrous gibs! -
Here's another one you guys might want to check out, it checks download and upload speeds and has other tests too, open ports, etc. and forums.
http://chi.speakeasy.net/Larry -
If you had 9 mega bits you would have a T1 or T3 pipe which costs a grand a month or what ever:D
that's pretty high, ours was 3 megabits, and bright house just announced our bandwidth has increased so i dunnoMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Mine from Broadband Reports:
2005-03-01 20:24:37 EST: 3940 / 345
Your download speed : 4035238 bps, or 3940 kbps.
A 492.5 KB/sec transfer rate.
Your upload speed : 354107 bps, or 345 kbps.
Broadband internet RULES!!! Whats dialup?
JohnNo excuses! -
i have optimum online. all i did was go there, no refreshing or anything. its not a T3 or anything just a regular $30 a month broadband connection. it is pretty fast tho huh
i was gonna ask if 2.3 was good...
never mind...**walks away kicking rocks***
2005-03-01 22:55:29 EST: 2398 / 425
Your download speed : 2455884 bps, or 2398 kbps.
A 299.7 KB/sec transfer rate.
Your upload speed : 435413 bps, or 425 kbps.Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
4.1 megabits per second
Communications 4.1 megabits per second
Storage 502.5 kilobytes per second
1MB file download 2 seconds
Thats my speedDan
4035.6 KbpsNever kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
danger boy wrote: »I went to Cnet.com and checked my bandwidth speed. here are the results. where it says. YOU in red. that is my speed at home.
check the speed here. try it. i think this site http://www.scanmyspeed.com/ shows you the correct result of your bandwidth. -
FWIW, this is a 6 year old thread. Also, the site you suggested sucks! It's nowhere close to correct. -
User sujith34 reported.
