my bandwidth speed
danger boy
danger boy Posts: 15,722
edited May 2011 in The Clubhouse
I went to Cnet.com and checked my bandwidth speed. here are the results. where it says. YOU in red. that is my speed at home.
PolkFest 2012, who's going>?
Post edited by danger boy on
  • faster100
    faster100 Posts: 6,124
    edited March 2005
    Heres mine, been wondering where another site to test bandwidth was..
    edit: don't hit refresh to redo the test, it will increase your reading, use the back button and redo... I hit refresh after i did this test and it went to crazy speeds...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2005
    Mine was 3,445 kbps. (Cox internet cable).
  • danger boy
    edited March 2005
    would the speed of your connection also have to do with your RAM and processsor speed? more RAM and faster processor will increase your speed?
    with two computer running WinXP
    computer 1 1.7gig P4 and 512MB RAM
    computer 2. 2.8gig AMD Athlon w/512MB RAM
    will both have the same speed measured?
    I know one can PROCESS faster than the other. but is the connection speed the same for this test?
  • nadams
    nadams Posts: 5,877
    edited March 2005
    danger boy- it really depends on how big the difference is. If you have too slow of a computer then it's probably not going to be able to handle all that traffic as efficiently as a faster one would. However, with your two computers, I don't think you'd see much of a difference.
    FWIW, here's another speed test site- http://www.bandwidthplace.com/speedtest/
    You can only run 3 tests per IP per month, but I like it because they have a number of servers around the country, not just in CA like DSLreports. Haven't tried the cnet test yet... will try now...
    Ludicrous gibs!
  • nadams
    nadams Posts: 5,877
    edited March 2005
    Just to show you, I got 1332.5 from cnet, and 2.9mbit from bandwidthplace, within a minute of each other.
    The reason speeds will go up if you refresh is because they actually use an image file to monitor the bandwidth. If you hit refresh, your computer already has that image file cached, so it reads it off your HD instead of off the internet...
    give www.bandwidthplace.com/speedtest/ a shot... their servers appear to be less busy.. or at least closer to PA. :)
    Ludicrous gibs!
  • danger boy
    edited March 2005
    i didn't refresh on my test. it was a one time only test. early in the day without much traffic I would assume.
  • Pauly
    Pauly Posts: 4,519
    edited March 2005
  • nadams
    nadams Posts: 5,877
    edited March 2005
    I was actually commenting on faster100's edit about refreshing.
    Isn't broadband a wonderful thing, guys? I could never go back to dialup...
    Ludicrous gibs!
  • faster100
    edited March 2005
    thats where i usually test, bandwidthplace.com
    I must have a pretty good pipe,
    4.5 megabits per second
    Communications 4.5 megabits per second
    Storage 553.5 kilobytes per second
    1MB file download 1.9 seconds
    Subjective rating Awesome
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Airplay355
    Airplay355 Posts: 4,298
    edited March 2005
    3784.8 kbps cablevision optimum online
  • Airplay355
    edited March 2005
    then i went and checked at badnwitdh place.com or whatever and look what i came up with
    9.4 megabits per second
    Communications 9.4 megabits per second
    Storage 1.1 megabytes per second
    1MB file download 0.9 seconds
    Subjective rating Unbelievable
  • Sami
    Sami Posts: 4,634
    edited March 2005
    www.pcpitstop.com report for my line at home:
    Bandwidth Down 15065 Kbits/sec
    Bandwidth Up 1863 Kbits/sec
    Average Ping 4 ms
    Ping Loss 0%
    Real download times, for single download the best I got was from Ubisoft, 8Mbits/s. Multiple downloads from Fedora site, 18Mbits/s. The best part really is the upload, I can now share files.
    Fiber is good, especially considering mine is $45 a month.
  • nadams
    nadams Posts: 5,877
    edited March 2005
    Airplay- I thought that bandwidthplace.com was capped at 8mbit... guess yours snuck through. Either that, or something is skewed there... What's your line supposed to be? mines supposed to be 3.5mbit, so my 2.9 is pretty decent considering it's during the day and there are 3 other computers on right now.
    Sami- You suck.
    Ludicrous gibs!
  • maggiefan
    maggiefan Posts: 223
    edited March 2005
    Here's another one you guys might want to check out, it checks download and upload speeds and has other tests too, open ports, etc. and forums.
    http://chi.speakeasy.net/
    Larry
  • faster100
    edited March 2005
    If you had 9 mega bits you would have a T1 or T3 pipe which costs a grand a month or what ever:D
    that's pretty high, ours was 3 megabits, and bright house just announced our bandwidth has increased so i dunno
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Strong Bad
    Strong Bad Posts: 4,278
    edited March 2005
    Mine from Broadband Reports:
    2005-03-01 20:24:37 EST: 3940 / 345
    Your download speed : 4035238 bps, or 3940 kbps.
    A 492.5 KB/sec transfer rate.
    Your upload speed : 354107 bps, or 345 kbps.
    Broadband internet RULES!!! Whats dialup?
    John
    No excuses!
  • Airplay355
    edited March 2005
    i have optimum online. all i did was go there, no refreshing or anything. its not a T3 or anything just a regular $30 a month broadband connection. it is pretty fast tho huh :)
  • beardog03
    beardog03 Posts: 5,550
    edited March 2005
    i was gonna ask if 2.3 was good...
    never mind...**walks away kicking rocks***
    2005-03-01 22:55:29 EST: 2398 / 425
    Your download speed : 2455884 bps, or 2398 kbps.
    A 299.7 KB/sec transfer rate.
    Your upload speed : 435413 bps, or 425 kbps.
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • mantis
    mantis Posts: 17,559
    edited March 2005
    4.1 megabits per second
    Communications 4.1 megabits per second
    Storage 502.5 kilobytes per second
    1MB file download 2 seconds
    Thats my speed
    Dan
  • Toxis
    Toxis Posts: 5,116
    edited March 2005
    4035.6 Kbps
  • sujith34
    sujith34 Posts: 6
    edited May 2011
    danger boy wrote: »
    check the speed here. try it. i think this site http://www.scanmyspeed.com/ shows you the correct result of your bandwidth.
  • jmwest1970
    jmwest1970 Posts: 846
    edited May 2011
    sujith34 wrote: »
    FWIW, this is a 6 year old thread. Also, the site you suggested sucks! It's nowhere close to correct.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited May 2011
    User sujith34 reported.
