Phase Plug design for MW65xx
1810121314
    xschop Posts: 5,046
    Do they thread on like the B&W's?
    VR3 Posts: 29,383
    Focal has a hole in the pole piece and the phase plug has a insert that connects and they add glue
    xschop Posts: 5,046
    Next up....
  • Gardenstater
    Gardenstater Posts: 4,720
    edited September 2022
    The one on the lower right looks like my Made In Mexico NOS MW6500 I got on eBay, even down to the whiteouted label with the "0" written in with pen.
    It will be interesting to see if they changed the VC OD to framepiece ID clearances. Oops. That's assuming you disassemble which you might not be doing.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,046
    Someone penned in "0" at end whereas other one clearly states 6501
    Also interesting this batch 6500's have 4 point swaged pole pieces.
  • xschop wrote: »
    My label looks the same and the vestigal tabs were the same square ones and the pole piece is one piece with the dimple like that one you show. My date is Sep 1999. I figure (hope!) that they had long since run out of MW6500 labels at that point.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,046
    6500 on left suffered major collision and magnet shift. The cone was creased and deformed, but we'll save it.
    Now that I've had 4ea 6500's on hand, I'll machine a VC jig to protect it while I clearance the base plate ID's.
    The 6500's will absolutely need this or the suspension slop will just let them rub no matter what...
    xschop Posts: 5,046
    Burning the midnight oil. Went to the shop whilst there was no traffic...
  • OOOOOH!
    Yes!
    I have some Etons from 2002 that would loooove to see a Polk version.
    https://www.eton-gmbh.com/en/products/home-hifi/product-archive/product/8-47232-hex/
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    xschop Posts: 5,046
    One done. 2 more to go. I calculated for 4-5 washers/shims in case Polk has taller baskets out there. I can adjust for cone surround clearance and jig adjustment...
    I used a Dremel paddle wheel sander. Took about 5 minutes to clearance to 1.085" ID nice and concentric...
  • gp4jesus
    gp4jesus Posts: 2,016
    Artist/machinist!
    *all connected w/Premiere ICs
  • Brilliant! Did you find that any of the voice coils were cocked like mine are? you are probably sleeping zzzzzzzzzzzz
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,046
    All 3 of these are running perpendicular. I have another 6510 apart and now I can say that besides the smaller baseplate ID, the 6500's are built exactly like 6510's and ohm out the same. I can test the suspension strength also by free-hanging the spud-jig on the VC and mic'ing the distance from top of spud to baseplate surface. They also match.
    xschop Posts: 5,046
    The 6500 with major magnet shift not only had a crease in cone, but VC was creased and slightly cocked until I took a Sharpie curved edge to it and smoothed it straight to where it clears the jig-spud. I simply pushed suspension to where base plate ID was used as the backing while smoothing it out.
    After running a test tone, I found that the spider was torn on that side too.
    I'm trying Eileens this time (suggestion by @westmassguy) and got the whole circumference re-done and set back straight.
    I'll run test tone again on this one after glue sets...
    xschop Posts: 5,046
    4ea 6500's done...
    More CRA CRA....
    Both these ohm out at 7.9 ohms. One has sticker gone but says BD0610-A
    The other has 2 stickers. One on top says 6501. Bottom sticker says 6510. ..
    I'm just extactic they haven't shifted and don't rub....
    Whatever they are, they're now hybrids...
  • gp4jesus
    What does “…more CRA CRA” mean?
  • slang for crazy
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Do you always use like a razor to cut the dust cap off as close as possible to the cone, or have you ever pulled the cap free by peeling it off?
    The extra mw I have that I played with... I couldn't cut it right, but I was able to peel the cone off. It was slightly nerve wracking.
    So trying to gird myself to remove the 4 from the 1C today or tomorrow.
  • I took a small dia. wood dowel and sanded one end on my belt sander at an acute angle and super glue gell'd an xacto blade to it. Worked very well. I made a left hand and a right hand one but only used the one. The blade plunge cuts very well to get started.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Oh! I forgot you did that!
    [To Tinkercad and the 3D printer!]
  • plastic_avatar
    plastic_avatar Posts: 727
    How are you cutting flush without buggering it up? Steady hands?
    I can cut to the glue/coating, but after that its... difficult enough that one slip and I might cut the cone.
    I guess that much of a lip there might whizz a little?
  • Gardenstater
    Steady hands help. I actually also used a magnifier and, along with the knife I showed, I skimmed a little at a time off to get down into the glue line. I don't advise trying to get all of the glue line off, in order to not cut into the paper/pulp that is untreated.
    With the knife I showed you can get down to the glue line pretty much on the first cut, except for the area near the wires. Better to deliberately leave some margin there!
    Also (important) it is better to use a sawing motion with the blade to let it do the work rather than brute force method of pushing it too fast through the material.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,046
    I cut right up to the base thats glued on. It actually adds to the cone stiffness and does not "whizz" at all.
    I started using the spud as a fast way to paint that small untreated area...
    This was the oddball one with white factory VC coil glue. Also have never seen this before...
  • plastic_avatar
    O.k., I cut all the dust caps to right above where the coating soaks in at the base. So they all have a slight raised edge.
    Before I put in the xschop aluminum beauties, I'm trying a printed one in my extra mw. I pulled the cap away on this one, so it doesn't have the same lip as the others.
    I used the backing from the aluminum roof tape stuff I'm putting on the exterior basket frames for my shims. We shall see how it goes!
    xschop Posts: 5,046
    Looks good. The most important thing is to make sure your pole-piece is concentric to the VC ID or you can be offset by shimming once done.
    What glue will you use on that plastic?
  • These are the shims I used. Vigoro plant labels with Frost King clear polyethylene tape additional thickness between the VC and phase plug. In the picture below the front shim has the PE tape also starting from between e and r in the word Every. Hard to see since it is clear.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • plastic_avatar
    Do you know the mm thickness of your shims?
    On glue:
    I used a tacky craft glue to test. I can pull/twist the plug out for other experiments, but it should be fine as a tester.
  • Gardenstater
    0.065" for the base layer which was a very flexible Vigoro plant label.
    0.012" total for the portion of shim laminated with the Frost King PE tape.
    Shim width = 0.75"
    length (total) = 2.5"
    length (pole piece) = 0.82"
    Lots of plant labels are unsuitable because too thick or too stiff. This plastic is very flexible. I had only enough for 4 shims. Haven't found any more of the 0.0065" stuff yet. I have 0.006" and 0.0085" and 0.003" (way too thin).
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • plastic_avatar
    Is that .012 inches total, laminated, or .12? Or mm? Man, I'm having trouble thinking today...
  • Gardenstater
    0.012" (0.305 mm) total. The Frost King PE tape must be 0.0055" (0.1397 mm) thick.
    These are for my MW6500 drivers. If your VC ID and pole piece OD are different those dimensions may or may not be OK for you, depending upon how much difference.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
