SDA II price in line?
  • joebass3
    Where are you located? I am in Maryland and have a decent pair of 2B studios that I'd like to sell. They look similar to what you posted above and they are pin/blade.
    pitdogg2 Posts: 27,847
    Pull the drivers would be the true way to tell. SDA2a had 2 x MW6510 and 2 XO boards. SDA2b had the drivers listed above on only 1 XO board.
  • ramm440
    Kinda far Mesa, AZ….The seller keeps telling me they are SDA 2 because thats whats printed on the back. SDA 2 had 3 drivers I believe. I’ll ask if he would be willing for us to pull the two drivers and identify them. There really is no other way correct?
  • ramm440
    Anybody give me an idea of a price to offer depending if they are sda 2a vs sda 2b. They are stock and local for me.
    txcoastal1 Posts: 13,520
    Click on sold or expired. Their truth worth is what you are willing to pay plus upgrading cost an additional $400 which you will never recover. The lows are around $250, high side $400. So you can start without insult $275.00
    https://www.hifishark.com/search?q=SDA+2B
    Hard to say availability is key to price. If upgrading caps is on the agenda then the 2a will be pricey. I personally didn't care for the 2a, the 2b wasn't as bright to my ears, even after I did all new caps, resistors and wire to my 2a's. The stock 2b was better sounding stock.
  • ramm440
    ramm440 Posts: 92
    edited September 2022
    Well seller has his facts a little backwards but that will work. Many of us have went the Neutrik speakon connection. That requires more work from you and changing the connection on the speaker itself. That plug you linked is plug and play.
    https://www.neutrik.com/en/product/nl4fx
  • ramm440
    Thanks on the interconnect cable question!
    F1nut, Is MC paint stripper Methylene Chloride? I just want to be careful not to damage the caps?
    F1nut Posts: 52,360
    Yes, but you can't buy it any longer because the gov't thinks they know what's best, which of course they don't. The new "green" strippers are worthless.
    Huh?
  • michaeljhsda2
    I think he meant the end caps.
    SDA SRS 2.3TL's
    SDA 2B TL's
    xschop Posts: 5,789
    I've stripped old varnish or lacquer off an old gun stock with Oven Off. Worked a charm and didn't harm the wood.
    F1nut Posts: 52,360
    Yep, got that. Just wondered what he thought would damage them.
  • ramm440
    F1nut, all do respect Im trying to learn from others mistakes here. If they were solid oak I would have no worries but since they appear to be a laminate that some chemicals might cause the laminate skin delaminate. I agree with you about gov knows best and new green crap deal. Hell I have chlordane which was very effective on eliminating termites without drilling digging etc.
  • ramm440
    Since the prior owner put a stain of some sort over the oak veneer. I might start with a citrus orange type of gunk that removes decals on automotive painted surfaces very effectively called Big Orange in a small test area.mtxy0nq8e79n.jpeg
    F1nut Posts: 52,360
    ramm440 wrote: »
    My profession revolves around wood and finishing. The veneer on vintage Polk speakers is pretty thick compared to today's offerings. Regardless, hand stripping with an MC based stripper will not lift veneer, old or new. Dip stripping is another story.
    Do yourself a favor, go to the hardware store and buy one of the paint stripper products. Strypeeze is one of the better current offerings. Do not use the Big Orange.
  • ramm440
    ramm440 Posts: 92
    Thanks so you recommend strypeeze since you have experience with it on veneer?
    ramm440 wrote: »
    Thanks, can you recommend a gentle stain removal product since you have experience?
    Jesse recommended
  • ramm440
    Maybe I should start with fine steel wool?
    F1nut Posts: 52,360
    NO, use stripper.
    F1nut Posts: 52,360
    ramm440 wrote: »
    I gots experience up the yazoo...lol
  • ramm440
    Yazoo is up my alley so I hired 3 strippers lol. Seriously I will start there
    To much talk about strippers and wood...sounds like a B(.)(.)B bar
  • ramm440
    Ok so looking at the dark stained 2bs I bought some previous owner really went haywire with an orbital sander and left some swirls from not using a fine enough sand paper before staining. Not sure but may leave them alone. I was wondering since the fabric has some discolorations from whatever is there a way to rejuvenate the black fabric since there are no tears or will they will they need recovered if I can’t tolerate them?
    Is the fabric a polyester of some sort?
    F1nut Posts: 52,360
    Resolve Fabric Cleaner
  • ramm440
    Thanks F1, I’ll give that a try.
