Center seems "weak"
  • gp4jesus
    gp4jesus Posts: 2,019
    French_guy wrote: »
    boston1450 wrote: »
    ^^^^ I wondered that also. Maybe test center on another channel & see if it follows. Does OP know history of this center speaker OR center channel on receiver?
    I bought the RTiA5 and the CSiA4 brand new, directly from Polk (it was end of 2014)
    to Frenchie: you answered Boston1450’s history question but you missed his test idea. He suggested you connect the ‘A4 to your left or right channel then listen & compare volume output to an ‘A5. Their respective sensitivities differ by a near-indiscernible 1dB. That removes a variable from the test.
    If they’re loudness is nearly the same or the same, perhaps the Center channel output could be suspect.
    *all connected w/Premiere ICs
    Clipdat Posts: 13,100
    I believe the issue is this candle that's sitting on top of the left speaker, it's throwing off the acoustics of the room and should be removed posthaste.
  • boston1450
    boston1450 Posts: 7,758
    It may also be a issue with the receiver/amplifier? Being you've owned speakers for 7 years, you know their potential. All you can do is try to single out options & hopefully stumble upon issue
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
