Cary CD306 SACD
WagnerRC
I could use a little help here. Has anyone seen now to order the case to make an internal repair. I keep getting the "No Disc" error and I would like to open up and try to clean the lens. I also purchased a replacement laser assembly it the cleaning fails.
This is a mystery how to get to the internals.
Thanks for any advice.
Bob
Bob
DarqueKnight had one, he might be able to help you.Political Correctness'.........defined
President of Club Polk -
I found some info that stated to unscrew the feet and you'll find the screws that attach the top cover in those holes.Political Correctness'.........defined
If you do have to replace the laser, typically there is an anti-static solder bridge that has to be removed. I don't know if the Cary laser has one but it's worth finding out.
Best of luck with repairs!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Looks like a solid unit. Good luck.
Ray was very helpful.thank you Jesse
So, do you remove the feet or what?Political Correctness'.........defined
...cliffhanger 2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Will be updated in ten years by a spam bot- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The feet do not need to be removed. There are 2 hidden screw holes under the “warranty voided if tampered with “ stickers.
There is very limited information on the net. -
Thanks for spilling the beans, that makes more sense.
At first I was studying pics online to see if I could figure it out. Next, I searched for discussions and found mention of the feet, so I went back to looking at pics and I just wasn't seeing the feet thing as there are boards/components in the way. However, since that was the only info I found I thought well maybe.
I had the player right in front of me and couldn't figure it out. I had to email Cary and ask for the secret.
Regarding the CD 306 and CD 306 Pro Version players, there really are no user serviceable parts inside.
The thing that typically fails is the laser assembly/transport assembly. Cary took Sony's SCD-1 transport
and modified it, changing it from a top loading transport to a front loading/sliding drawer transport...and that's where the troubles began.Proud and loyal citizen of the Digital Domain and Solid State Country!
