The Space Thread -
12357…13
    Viking64 Posts: 7,836
    Carbon footprint?
    Is that some kind of metaphor or are scientists trying to determine the age of The Bathmat of Turin?
    Tony M Posts: 12,035
    Time Travel to other galaxy's somewhat simply explained. B)
    https://youtu.be/an0M-wcHw5A
  • NotaSuv
    NotaSuv Posts: 3,871
    audioluvr wrote: »
    The actual launch has none but the massive production to prepare for it is probably quite a lot
    lol that really depends upon what fuel is being used Space X uses a loaded with carbon fuel while other companies use a zero carbon fuel...LOTS of soot emitted into upper reaches
    Space rockets may not be very environmentally friendly. Space launches can have a hefty carbon footprint due to the burning of solid rocket fuels. Many rockets are, however, propelled by liquid hydrogen fuel, which produces ‘clean’ water vapor exhaust, although the production of hydrogen itself can cause significant carbon emissions.
    treitz3 Posts: 20,367
    edited August 2022
    Imagine being able to focus in on the engraved flame of the torch on a dime from 100 miles...
    Well, that's what this telescope (that will hopefully be ready for it's first images at or near 2030) will be able to do. You think The Hubble telescope provided great imaging? It got figuratively pushed aside over the excitement of the images that we have recently seen from the James Webb telescope.
    This telescope will be 4 times more powerful than that of the James Webb telescope! Just the mirrors will have to go through a 2 year polishing effort. They just secured a large chunk of the funding and many of the components have been under development/construction for a while already. The first two 8.4m primary mirror segments have already been completed and placed in storage, three segments are in various stages of grinding and polishing, the sixth segment is in the initial stages.
    The GMT primary mirrors were made at the Steward Observatory Mirror Lab in Tucson, Arizona. They are a marvel of modern engineering and glassmaking; each segment is curved to a very precise shape and polished to within a wavelength of light—approximately one-millionth of an inch. Light from the edge of the universe will first reflect off of the seven primary mirrors, then reflect again off of the seven smaller secondary mirrors to travel down through the center primary mirror hole to form a single focus on one of various advanced instruments that will analyze the light.
    It will be located at the Las Campanas Observatory in Chile.
    For more information if you are interested -
    https://petapixel.com/2022/08/09/1b-giant-magellan-telescope-to-have-4x-the-resolution-of-james-webb/
    https://scitechdaily.com/the-giant-magellan-telescope-will-revolutionize-our-view-and-understanding-of-the-universe/
  • NotaSuv
    9 pm tonight the 21 million pound Artemis 1 rocket rolls out of VAB and to its launch pad where it will stay until 8/29 first day of the launch window....it's quite an impressive sight to see just sitting on the pad
  • verb
    verb Posts: 10,176
    Roll out is happening now! Slight weather delay. The official webcast is poor, but I found this one.
    https://www.nasaspaceflight.com/2022/08/artemis-1-launch-rollout/
  • NotaSuv
  • NotaSuv
    Expectations are well over 100,000 coming into the area to view the launch...we will probably be atop the roof for a good view.....last major launch it took over 3 hours for traffic to clear out....can only imagine the crowds for the next manned launch to the moon
  • verb
    verb Posts: 10,176
    NotaSuv wrote: »
    Dude I am so jealous that you get to see things like this all the time! For me, it's a bucket list item!
    mhardy6647 Posts: 35,562
    edited August 2022
    treitz3 wrote: »
    The GMT primary mirrors were made at the Steward Observatory Mirror Lab in Tucson, Arizona. They are a marvel of modern engineering and glassmaking; each segment is curved to a very precise shape and polished to within a wavelength of light—approximately one-millionth of an inch...
    I am pretty sure y'all know this, but the wavelength of light depends on its color (or, perhaps more accurately, the color of light is determined by its frequency) -- not really all that different than sound (bass and treble frequencies/wavelengths), although, of course, the speed of propagation is very different :) and light waves are transverse while sound waves are longitudinal.
    Which is actually not why I replied to this post! :p
    Thinking about polishing glass to arbitrary levels of flatness (i.e., danged flat) can be assessed in a crude but surprisingly effective way, especially with flat pieces of glass (e.g., camera lens filters). Remember learning about rings of Newton in high school? B)
    Cool stuff -- a way to visualize incredibly small differences (fractions of a wavelength of visible light). No instruments required! Just eyeballs. Sort of like selecting interconnects or speaker cables. ;)
    https://www.animations.physics.unsw.edu.au/jw/light/Newton's-rings.html
    You can kind of get the idea from this, although these examples are rigged in that one piece of glass is macroscopically not flat. :)
    https://www.edmundoptics.com/knowledge-center/application-notes/optics/optical-flats/
    lambda = wavelength
    The wavelength of, say, blue light is very small. The colors we see as "blue" have wavelengths in the range of 450 to 495 nanometers (i.e., 450 to 495 billionth of a meter... don't make me convert that to inches!). that non-flatness of lambda/2 (so, ca. 225 to 247.5 nanometers) is clearly visible. :)
    You can measure extremely small deviations from perfect flatness by the appearance of the pattern when two "flats" are placed together!
    I love stuff like this -- when we can see data from the extremely (!!!) microscopic world... with our own, very macroscopic point of view! :)
    Sorry -- I am a geek-nerd. B)
    Relatively speaking? One-millionth of an inch variance is still not flat.
    But, I digress....they are curved mirrors, after all.
  • jdjohn
    jdjohn Posts: 3,462
    Thunderstorm from space
    ^^^ Cool shot! ^^^
    I have seen many shots of Jupiter before but never any like the ones MBBL linked from above. The first one is the actual shot. The second one is the shot explained. The Webb NIRCam composite images seen below are from two filters – F212N (orange) and F335M (cyan).
  • NotaSuv
    EW YORK -- If you ever dreamed of naming a planet, here is your chance.
    The James Webb Space Telescope is discovering new planets outside our solar system, and now 20 planet names are up for grabs.
    Here are the rules: You can't name a world after yourself or your pet, or give it a religious or military name.
    The contest is open through Nov. 14.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited August 2022
    Cool !
    So I guess Erectus Maximus is out because of the religious or not name it after yourself restriction
    ...or both
    (in some cases 🤗).
    I'll just let myself out, be back. later to apologize.🥴
    Cool !
    ...or both
    (in some cases 🤗).
    Incontinentia Buttox Buttocks
    ... and what is a military name?
    Sarge?
  • mrbigbluelight
    Rear Admiral ? 🤔
    Yes....I think one could do wonders with that .... 🥴🤔
    pitdogg2 Posts: 27,918
    treitz3 wrote: »
    ^^^ Cool shot! ^^^
    The space nerd on TV this A.M. said taking a picture of Jupiter clearly is very hard because it spins so fast....
    Odd question...since Jupiter has no surface, how long is a Jupiter day considered?
    treitz3 wrote: »
    Tom, I was wondering the same thing.
    I didn't know that it had no surface, I had just thought that it was so inhospitable that anything we send would just get ate up before touchdown.
  • ken brydson
    ken brydson Posts: 9,107
    treitz3 wrote: »
    Kinda like my Seahawks this year. Oops, wrong thread..
    treitz3 wrote: »
    Like you're surprised! Try the Bears on for size.
    So, I got curious and looked it up.
    "The "canonical" (that is, commonly accepted) day length on Jupiter is determined by the rotation rate of its magnetic field, which is nine hours, 55 minutes long."
    They say you learn something everyday. Well, I may have been told this before but today, I learned (or was reminded again) that Jupiter is the fastest rotating planet in our solar system and that it's measured by its magnetic field (that part, I did not know).
    More useless, trivial p o o p that I will carry around with me....like I need more.
    Nice!
    A 9-hour day... :p
    Some people would love the 3 hr. work period 3 days a week. :D
  • NotaSuv
    THE moon launch is a GO for Monday...already thousands in the area as there is a night SpaceX launch this weekend, and night launches always draw a crowd..amazed at the number of visitors from out of Country.
  • jdjohn
    jdjohn Posts: 3,462
    edited August 2022
    Yep, Jupiter is one of the 'Gas Giants', with a relatively small rock core...but nonetheless still larger than Earth. Most of Jupiter is metallic liquid hydrogen. I'm not sure I can even process what that is like. I guess it's something similar to liquid Mercury.
    Here's an image:
    I'm just the opposite of Jupiter.
    I have a rock exterior and a gaseous core.
