Polk Magifi Max volume adjustment
Ken_Yeung
Just come up with a strange situation. I set up my current Polk Magifi Max with my new Sony TV. It works properly for a night but not for the following day. After hours of trials, the sound bar works but when I try to adjust the volume, the sound bar reacts with no sound but not turn off. If I turn it off and turn it on again, it works again. The strange point is even when I use my TV remote controller, the sound bar also reacts with no sound immediately. Has anyone come across with similar situation? Appreciate all your thought and advice. Thanks.
Answers
Hi, just a look at your HDMI port you are using on the Sony, is it ARC or eARC? And maybe go through the HDMI config on the Sony. I had some issues on a Panasonic TV and my Magnifi 2. Goog luck.
Thanks for your advice. Mine is eARC. I tried to config my Sony TV but it seems that it doesn't help too much. Anyway, I will try again to see if it helps. Fingers crossed.
