In Search of... AI-1 Amplifier Interface
dogwallop
Hi all, we are in search of an AI-1 interface cable for our system. If anyone has one we'd really appreciate the help.
Thanks!
Thanks!
Slim pickings on dem. Try fleabay as well.
You can easily build one that's much better than the Polk original. Search "dreadnaught" for specifics.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Here you go. It's not the cable, it is a very good option for an off the shelf build. The link and stock number to buy direct should you choose that path.
https://forum.polkaudio.com/discussion/131848/avel-lindberg-y236906-transformer-800va-for-sda-dreadnoughts
Realistically you may get lucky on an original cable. They rarely come up on ebay.
I Started with a cable, went to the 800va and then to the 1000va torrids. Each way was a step up.
What gear are you running ?
That would be the way to go right there..
