In Search of... AI-1 Amplifier Interface
Hi all, we are in search of an AI-1 interface cable for our system. If anyone has one we'd really appreciate the help.
Thanks!
  • la2vegas
    la2vegas Posts: 776
    Slim pickings on dem. Try fleabay as well.
    heiney9 Posts: 25,721
    You can easily build one that's much better than the Polk original. Search "dreadnaught" for specifics.
    pitdogg2 Posts: 27,914
    Here you go. It's not the cable, it is a very good option for an off the shelf build. The link and stock number to buy direct should you choose that path.
    https://forum.polkaudio.com/discussion/131848/avel-lindberg-y236906-transformer-800va-for-sda-dreadnoughts
    Realistically you may get lucky on an original cable. They rarely come up on ebay.
    I Started with a cable, went to the 800va and then to the 1000va torrids. Each way was a step up.
    What gear are you running ?
