Worth it?
    F1nut Posts: 52,189
    Drinking a lot and bad sound seem to go hand in hand.
  • ramm440
    ramm440 Posts: 92
    I’ll be darned! Two divorced 555s in stereo sound good enuff for me. They’ve been with me since 1987 and stayed with me through two wives…I need another Coors
    pitdogg2 Posts: 27,632
    ramm440 wrote: »
    Just about time to replace the big blue caps. 😉
  • ramm440
    ramm440 Posts: 92
    Is replacing the blue caps a preventative to prevent damage or improve sound quality or maybe both ?Thanks
    edited May 2022
    The big blue caps drift badly over time. The original gfa 555 is long in the tooth and replacing those and whatever electrolytics will bring it back into spec. Pretty simple design.
    It would improve sound and headroom.
  • ramm440
    ramm440 Posts: 92
    Maybe I can get you to do it for me if you live in Phoenix?
    ramm440 wrote: »
    Theres more to it than just switching them out, it will need re-biasing more likly than not. I'm a loooooong way from Phoenix.
  • ramm440
    ramm440 Posts: 92
    Sounds like lyrics to a Glenn Cambpell song lol. Know anyone capable in this neck of the sticker patch?
    ramm440 wrote: »
    I'm sorry I do not. Honestly send Adcom a phone call or email. They've been very responsive in the past.
    Here is a good read, I had one of these amps and I couldn't throw enough money at him to service mine lol
    https://hoppesbrain.com/2015/10/06/some-notes-about-restoring-a-gfa-5802/
    From Adcoms website
    J&B Distribution. Inc
    Jim Donnelly
    Phoenix, AZ
    PH: 480-607-2277
    EM: jdonnelly@adcom-usa.com
  • ramm440
    ramm440 Posts: 92
    The calls get forwarded Jim’s old partner in New Jersey. He told me if it works don’t fix it because may lead to numerous more problems. I guess Ill leave them be.
    audioluvr Posts: 6,023
    I would get a second opinion.
  • ramm440
    ramm440 Posts: 92
    Search Adcom rebuilds
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2022
    Electron Kinetics Eagle amp and preamp?
    Holy shiitzkie! Turn 'em up real loud, see if you can get beamed into the ether like John Iverson, never to be seen again.
    (Or, maybe they'll just transport you to Singapore.)
    Supposedly, those amps were SUPERB in their day. The 7A was legendary. The 2 competed with Adcom 555, B&K ST-140, and such. I don't know about the preamp.
    https://www.stereophile.com/solidpoweramps/electron_kinetics_eagle_2_power_amplifier/index.html
    https://charleyproject.org/case/john-gordon-iverson
    Post edited by Schurkey on
  • ramm440
    ramm440 Posts: 92
    He probably still has it too
    So did he invent the rail gun? Or did he scam the mofia into thinking he did for some quick cash and got buried in concrete for it? Sounds like a good movie plot.
  • ramm440
    ramm440 Posts: 92
    Make a good true life movie…..
  • ramm440
    ramm440 Posts: 92
    Im keeping my open for a deal..How do these compare to my SDA 2Bs?
    Check out this item on OfferUp. https://offerup.co/3zbTeTpSUqb
    edited June 2022
    ramm440 wrote: »
    Keep the SDA 2b. Those are good with the exception that the drivers mw6509 were only used for two models, the SDA 1b and that model. If you like those keep and eye open for the pin/blade model which is based on the SDA 1c design. The drivers are a little more common mw6510 and mw6511
    Those are a little over priced IMHO
  • ramm440
    ramm440 Posts: 92
    Thanks! So there’s a blade pin cable Sda 2b that is the desired one?
    I planned on keeping the the 2bs I have which are blade blade but wanted another set for my second Adcom amp.
    F1nut Posts: 52,189
    Looks like the pin/blade version.
    edited June 2022
    I stand corrected. I seen the plug for the old blade/blade socket. I overlooked the pin/blade socket in the cup.
    Ol'eagle eyes @F1nut 😉
    The SDA SRS 2 had two versions
    Blade/blade interconnect based on the SDA 1b with 4 mw6509 drivers. Very scarce
    Pin/blade interconnect based on the SDA 1c
    2-mw6510
    2-mw6511
    The pin/blade is the more desirable.
    That being said the mw6511 drivers are just about as scarce as the mw6509
    I still think $700 is a little steep, offer $500 and hopefully come to a good outcome in the middle.
    The SDA SRS 2 do offer a huge soundstage.
  • ramm440
    ramm440 Posts: 92
    I think I will pass on them because the cabinets are a little bigger than I expected. I will keep watching for another set of sda 2bs. I appreciate you guys responding with your knowledge of these!
  • odcics2
    odcics2 Posts: 393
    And edibles improve sound! :D
  • ramm440
    ramm440 Posts: 92
    You funny guy! Started at age 12 but quit by age 20. To much paranoia back then because of getting busted.
    Still lookin for a second pair of sda2bs if ya got em just dont smoke em please! :D
    F1nut Posts: 52,189
    odcics2 wrote: »
    If you need that to improve sound you've got bigger problems.
