Analog radio
First, what is better for indoor fm radio antenna 50/75/ 300 ohm
I hear that 300 ohm improve sound quality, the 300 OHM FM antenna
Answers
    pitdogg2 Posts: 27,683
    You can get a balun to go from 75 ohm to 300 ohm and decide for yourself.
    It really all depends on what you tuner is set up for. Older tuners were only 300ohm later they had both inputs.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,353
    edited April 2022
    It's going to depend upon what antenna you're using. The idea is to match the antenna's impedance (at radio frequencies) with the FM tuner's input stage. For example if it is a simple FM antenna that came with classic receivers then that is a 300 ohm impedance antenna which would be connected to the 300 ohm antenna connection on the receiver. If, on the other hand, it was an outdoor FM antenna most owners would use a 300 to 75 ohm converter on the antenna and 75 ohm coaxial cable to the tuner and connect to the 75 ohm input on the receiver.
    mhardy6647 Posts: 35,455
    Not sure if the input on any particular FM tuner "front end" is natively 75 ohm or 300 ohm.
    Every added impedance matching device (i.e., 'balun' = balanced/unbalanced transformer) causes loss of signal. The less 'connections' of any sort, the better (at least in theory). :)
    a priori it's not really likely to make a big difference, though.
    a prioriI like 75 ohm unbalanced for noise rejection, but I have used both, with various flavors of indoor & outdoor antennae :p
    Antennae are interesting things: there's science, art, and magic involved in the design and implementation of an antenna. :)
  • SeleniumFalcon
    And don't forget the "skin effect"!
    Ve don't forget ze skin effekt!
    fixed it fer ya
  • henryroy57
    Hello guys, I am interested in learning about electronics because of my passion. As of now, I am studying matric at Okara school, but I plan on becoming an electrical engineer in the future. That's why I am here for learning about it.
    henryroy57 wrote: »
    If you're not a bot or spammer -- howdy & welcome.
    I dont' know what matric or Okara are. You may find other/better sites for "learning about EE", though.
  • henryroy57
    henryroy57 Posts: 2
    henryroy57 wrote: »
    It's ok I solved my problem but thanks for the reply.
  • Nightfall
    Nightfall Posts: 10,083
    You never discussed any problem.
    afterburnt wrote: »
    Village Idiot of Club Polk
    txcoastal1 Posts: 13,519
    henryroy57 wrote: »
    Not sure what matric is either...but fried okara with shicken and mash taters is the bomb...just sayin'
  • skrol
    skrol Posts: 3,483
    henryroy57 wrote: »
    henryroy57 wrote: »
    Someone's in denial.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jbreezy5
    jbreezy5 Posts: 1,141
    Nightfall wrote: »
    That is the problem.
    Glad we were able to help.
