Are there any good on wall speakers?
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
Title says it all, are there any on wall speakers that sound great? I don’t mean good enough to be passable for home theater, I mean truly great sounding speakers even for music.
  • BlueFox
    BlueFox Posts: 15,250
    What is an on wall speaker?
    VR3 Posts: 29,539
    I believe the mythos from definitive would qualify for on wall
  • tratliff
    tratliff Posts: 1,809
    When I was at Axpona Focal was demoing a pair that looked impressive but I didn’t spend any time with them.
  • PSOVLSK
    PSOVLSK Posts: 5,399
    I recall Usher having a pair that was pretty good. Probably not as good as what you’re looking for though, as I wouldn’t say they were fantastic.
  • marvda1
    marvda1 Posts: 4,962
    I think KEF has some.
    Puritan PSM156
  • rooftop59
    rooftop59 Posts: 8,120
    I think they are out of production, but totem had some on wall called the Tribe - there is a pair on eBay now. I’ve never heard them but they look VERY intriguing.
    I feel like the best research goes into in-wall speakers - there are lots of high end options available…
    Game Room 5.1.4:
    Bedroom 2.1
  • Emlyn
    Emlyn Posts: 4,814
    The Polk Reserve R350 is intended to fill that niche as a wall mounted speaker than can be used for left, center, right. Mcintosh also has an LCR model for much more money. Others likely do as well, but I haven't bothered to look.
    The problem I see is the form dictates the performance. People who buy LCR speakers usually want them with cabinets that aren't deep so they don't stick out away from the wall much. This is why a model won't sound truly great but merely good enough for the purpose.
  • rooftop59
    Emlyn wrote: »
    .The problem I see is the form dictates the performance. People who buy LCR speakers usually want them with cabinets that aren't deep so they don't stick out away from the wall much. This is why a model won't sound truly great but merely good enough for the purpose.
    That’s also why I think there are more high performance in walls, because the infinite baffle configuration makes better sound possible…
    Game Room 5.1.4:
    Bedroom 2.1
