Cutting up a long Pangea power cable, should I?
  • Emlyn
    Emlyn Posts: 4,827
    The OCD part of me would want to cut both molded ends off and just use the new cables with new plugs on each end.
    :D
    I don't think Pangea would offer a cable rebuilding service since their cables are sourced for distribution but I could be wrong.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    You cannot reuse the terminations as they are permanently molded to the cable.
    Agreed 100%. I’ll just be cutting the cord the desired length from the factory plugs, not trying to take them off or anything. I’d def have to cut those off if I was wanting that but I’m gonna leave them, it’s just easier that way.
    I’ll post some pics once I get to doing it. Heat shrink is a must bc I feel the putter jacket is going to come undone pretty quick once I cut it. I may put glue near where I cut the wire it doesn’t do that
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
    pitdogg2 Posts: 27,335
    Adhesive shrink wrap..... done
  • Mr. Sharpe
    Emlyn wrote: »
    Funny thing is is my ocd side may end up needing that too lol
    SWEET!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Emlyn wrote: »
    :D .
    Now that you said that I’m probably gonna do it. You had to go and say it😅
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Cut! Very thick tough stuff. I like seeing the foil shield and wire covering for it. This is good quality cable. Oh and this cable will only yield three cables because it’s only a 2 meter length. Idk where me thinking it was 12 or 14’ came from.
    Stripped! Idk if you can see it but there’s one strand of solid core for I’m assuming low frequencies, I remember reading that somewhere. I ended up just melting the edges of the putter jacket and it worked fine.
    Connected! This is a sonar quest IEC connector, pure copper from China. I had this connecting my power conditioner. They’re a tight fit!
    Finished! It presents well imo but I don’t see it behind components;) the cables will still end up a little longer than their .6m lengths but they’ll do.
    I’m pleased
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Emlyn
    Emlyn Posts: 4,827
    Toolfan66 Posts: 18,189
    Looks good, the build quality looks good on the cable, nice to see the innards since I own many Pangea cable’s..
    So you didn’t do both ends?
    I like the Sonar ends, very good grip yet not death grip.
    I've used several sets of them.
    Nice job.
  • Mr. Sharpe
    Emlyn wrote: »
    Nice work!
    Thank you!
    Toolfan66 wrote: »
    Nah I left the plug end to save on more plugs
    Nice job.
    They’re inexpensive and look cool being clear and black!!!!!!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    VR3 Posts: 29,553
    Man the pangea wire looks good. Odd there is oxidation given their construction but still very solid
  • Hermitism
    Hermitism Posts: 4,337
    I've very much enjoyed this thread.
    F1nut Posts: 52,009
    Chinese copper for ya.
    Supposedly it's Cardas copper ..
  • Mr. Sharpe
    I thought cardas only did the mkII cables? This isn’t a mark two version
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    VR3 wrote: »
    Didn't even catch that.. :neutral:
  • Hermitism
    MKII (Cardas) will have a blue spiral sewn into the fabric sheathing.
    Mr. Sharpe wrote: »
    You are correct, The original was some company in Japan that was "supposedly" top quality copper. They went to Cardas after they lost the ability to buy from Japanese supplier.
  • Emlyn
    Emlyn Posts: 4,827
    edited April 2022
    Right. SE was PCOCC for the center conductor and run of the mill OFC for the rest. SE MKII is Cardas for the center conductor and OFC for the rest. I don't think they changed anything else inside the cable with shielding. A generic IEC power cable is just three stranded conductors usually so some thought went into the Pangea products. I remember seeing some photos of counterfeit power cords over the years where generic stranded conductors had been put inside a thick fancy looking jacket stuffed with cotton.
    SCompRacer Posts: 9,123
    One could say you 'nailed' it. Nice work!
  • Mr. Sharpe
    Mr. Sharpe wrote: »
    That’s interesting. So what we’re getting a single good quality solid copper core👍 Awesome!
    Emlyn wrote: »
    you can still buy stuff like that too! it’s like they use “pure cotton insulation” as an audiophilers selling point when it does nothing different from ordinary paper lol they do make some pretty looking power cords but for just shielded wires you’re just buying a pretty cable. Although terminations claim to be rhodium plated and/or silver plated copper. Some will say bronze and platinum too
    SCompRacer wrote: »
    Thanks! I should take a close up of that razor sitting there, it’s amazing it was cutting anything!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,836
    Good job @Mr. Sharpe! Glad you included all of us in the venture.
    Harry / Marietta GA
  • invalid
    invalid Posts: 1,530
    If the dielectric was made out of cotton it would be better than Teflon, cotton has a dielectric constant of 1.3 and Teflon is 2.0
  • Mr. Sharpe
    We’ll I’m glad I did, it’s been a super long time since I’ve shared pics of things I’ve done in my system like this.
    invalid wrote: »
    Shoot that’s awesome, may have have to get me some now 😁
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
