Can’t find PolkAudio speaker model number
Flora
Flora Posts: 3
I wanted to find out if my front speakers are bi-amp and the second set of terminals hooked up To the extra sp1 outputs on my rx-a2070 receiver (and if it really makes a difference…)
It also has an attractive angled top if that helps identify the model
Best Answers
  • Gardenstater
    Gardenstater Posts: 4,195
    Answer ✓
    I don't know the model# but if you look at the back of the speakers, if they are bi-ampable or bi-wirable they will have 4 binding posts each and you will see a couple of straps that should be in place. Those would have to be removed if you try bi amping or bi wiring, assuming they are capable of it.
    https://www.audioholics.com/frequent-questions/the-difference-between-biamping-vs-biwiring
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Emlyn
    Emlyn Posts: 4,374
    edited April 2022 Answer ✓
    I poked around a bit more based on things said on the forum in the past and they appear to be Polk RM8000T or RM50T towers. The VM and RM series came out around the same time about 15 years ago from what I can tell. They were intended for use with wall mounted flat screen panel TVs that were coming out.
    https://www.woot.com/offers/polk-audio-rm8000t-rm50t-tower-speakers
    The RM50T was the dark color model and the RM8000T was the silver color.
    Clipdat Posts: 12,619
    Answer ✓
    Flora wrote: »
    You shouldn't do this because it's not true bi-amping (meaning two amplifiers & two power supplies), because everything is still coming from the same shared power supply inside the AVR. You won't gain any performance by doing this.
    Keep the wires connected to either the top set or bottom set of posts, with the jumpers in place.
    If you want to upgrade the speakers or amplifier/AVR to something higher quality, we can guide you, but there's a hard limit to what you're going to hear out of your current Yamaha AVR and speakers.
  • Flora
    Flora Posts: 3
    Answer ✓
    Clipdat wrote: »
    Your Yamaha AVR has pre-outs, so you'd gain a lot more by hooking up a dedicated 2 (or ideally, three channel, with a center channel speaker) amplifier and going in that direction.
    E1D29828D7A84730AF04CA250F132CC2_12075_3067x1550_de61400e702248342274ab622448a03a.jpg
    Basically all depends on how serious you want to get and what you're trying to accomplish (ex. movies, music, both etc). But yeah simply trying to use an "unused channel" to fake bi-amp using an AVR is not going to get you anywhere.
    I have hooked up a 5.1 configuration. I recently reconfigured my living room and noticed one of the jumpers is missing from my front left tower speaker. Manual for RX-A2070 say you can bi-amp using front SP1 outputs. I already have an extra speaker wire and need only one more to bi-amp. Or I need to locate missing jumper (or get replacement). I don’t need more performance (if performance is measured in volume). My place is small and I don’t believe I’m stressing the speakers at all. I listen to blues/jazz. My husband goes for Led Zeppelin’s music style. Periodically watch moves and I go for Jason Bourne type movies with lots of crashes and explosions.
    From your prior posts, sounds like I should just replace the jumper. With no extra sound details from bi-amping. I appreciate the advice.
    You can make yourself a new jumper using a short piece of speaker wire, and put it in where the metal jumper used to be. Like this:
    This guy replaced both his jumpers with speaker wire:
  • boston1450
    boston1450 Posts: 7,474
    Answer ✓
    Throw those jumpers away & use clean speaker wire. Cut little peices & run em like the jumpers were.... That will work better then those cheesy metal jumpers
    Randy/Maine
Answers
    pitdogg2 Posts: 24,604
    Pretty sure that is not a Polk audio speaker. At any rate you're not gaining anything, in fact you may be actually reducing the power going to the speakers. Bi-amping with a receiver is marketing flim/flam. The best benefit would be to make jumpers to replace the brass strap with IF you do indeed have 4 binding post.
    VR3 Posts: 28,066
    Looks like the old Polk vm but u can't find that exact driver arrangement
  • Emlyn
    Emlyn Posts: 4,374
    I don't recall seeing a Polk Audio product looking like those.
    If there aren't any external labels on the back of the cabinets indicating they are a Polk Audio product, maybe unscrew one of the speaker drivers and look inside for any identifying labels such as a driver number or something on the crossover board inside.
    VR3 Posts: 28,066
    This is the closest i can find
    VR3 Posts: 28,066
    Rm! Man... This is a sign I am getting old.
    Sid the old man 🧓
    treitz3 Posts: 18,369
    Damn, if this don't make ya' feel old....
    VR3 wrote: »
    Sid the old man 🧓
    At least you had an inkling, I've NEVER seen anything close to those, then again I'm much older ....
    Ummm what were qe talking about?
    F1nut Posts: 49,825
    You can't bi- amp with an AVR, PERIOD.
  • engie490
    engie490 Posts: 426
    Some AVRs allow you to re-assign 2 internal amps to "biamp" the front channels. Given that they share the same power supply though, I'm not sure I disagree with your assessment.
    Sonus Faber Liuto / Coda Continuum / Anthem STR Preamplifier / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Ikeda 9C2 & Dynavector XX2 Mk II carts
  • Flora
    Flora Posts: 3
    Emlyn wrote: »
    That is EXACTLY the model I have. MY BAD, though, as I should have mentioned that I am ancient and thought I bought these speakers (new) about 10 to 15 years ago…. Back then there were a large number of people buying into the promise of the tiniest cube speakers and these were going cheap at Sound and Vision. (You’re really old if you remember walking into their sound room to compare speakers before you bought them. I just can’t image relying solely on reviews; Just not sure I hear the same as someone else…)
    I really appreciate this as I was wondering about their bi-amp capability and got may answer!
    edited April 2022
  • Emlyn
    Emlyn Posts: 4,374
    You can replace the jumpers on the speakers with short lengths of speaker wire if you can’t find the originals. No need to run extra speaker wire to them. They’re not hard to drive with even a modest receiver and the one you have is very good.
  • boston1450
    edited April 2022
    Nm. Vanilla format stinks
    Randy/Maine
  • BlueFox
    BlueFox Posts: 15,251
    boston1450 wrote: »
    Agreed. When I look at this thread Vanilla goes to the first post instead of the one after the last post when I previously viewed the thread.
  • boston1450
    Exactly. What it should show is (check mark) that the OP agrees OR accepts all suggestions as they happen. Not move the post.... Future readers looking at archived threads must be scratching their heads.
    Randy/Maine
  • PSOVLSK
    PSOVLSK Posts: 5,079
    If those are anything like my R50’s (and I suspect they’re better), you’d be very surprised at how much better they sound with good amplification.
    Glad you were able to get your questions answered.
