Hello all
  • Oh, but I glued the first one without seeing the polarity was wrong, they have the little red dot on the positive side, so I clipped off the connectors on the wires, and reversed them. So now on that one the smaller terminal is positive.
    xschop Posts: 5,333
    That was @VSAT88's thread. Good work, because thats the only one I haven't modded because I Karma'd off a perfectly good set here from the custom 8Tls.
    I saw @DarkKnight's thread pics where it looks like the circular plastic and silk dome can drop right in as well.
  • Yep, the plastic baseplate is beveled, but there is a gap between the edge of the silk and the bevel, and you cant really see it very well when its covered in glue. I found it easier to flip them over and line them up upside down. Dang, now I wish I took pictures. I will pop one apart and take a few, as it may help someone else, as you fine folks helped me.
  • The black plate with the terminals has a little residual glue on it from the factory, but it pops off with minimal effort. I got some on there as well so I better not pop it back off, as its lined up nicely now.lining it up on the plate is tricky with contact cement, I just stuck one tiny section of it down and flipped it over and adjusted to the center.
    As you can see the fluid in them is brown, not sure how bad that is, not real sure what color it's supposed to be. A voice coil did burn up in there, so it's probably not ideal.u8bchpe6hrm1.jpg
    xschop Posts: 5,333
    Can you post in Vsat88's thread so all the tweeter rebuild info is there? Thanks for sharing and welcome aboard.
    F1nut Posts: 51,934
    Ferrofluid is a dark brown color with a fluid viscosity. Over time the viscosity can thicken causing it to become ineffective. If yours has turned to sludge it must be changed.
  • Ah thanks. Ok I will order some fluid, and give that a go. Not real sure how to get it out of there, or how much to put back in.
    F1nut Posts: 51,934
    There is online info and videos showing what to do. Parts Express sells the fluid.
  • Gardenstater
    Gardenstater Posts: 4,799
    Welcome!
    I'm not understanding how it could be possible to get the polarity wrong. I mean yeah, I see how you could have the positive on the left or right, depending upon how you orient the voice coil/dome/terminal assy relative to the plastic tweeter bezel but it seems to me the polarity should be foolproof because of the different size fastons.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Yep, I glued the coil down with the negative wire going towards the positive, larger terminal. So I just went with cutting the ends off the wires coming from the box and switching them around.
  • Gardenstater
    Oh I see thanks. :) You got the glue down surround types without any terminals and re-used the Polk terminals. Or maybe I'm confused and they are all like that.....I've been following this mod or at least I though so.....back to the original thread for me to reacquaint myself I guess.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Yep, they are all like that, well, for sl2500s anyways, as far as I could find.
    F1nut Posts: 51,934
  • Gardenstater
    Our ferrofluid kits come with pre-measured packets of ferrofluid which are used to replace the old fluid in speaker air gaps when replacing diaphragm and coil assemblies.
    Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling.
    Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling. It should be used to replenish drivers treated previously with ferrofluid. With care, it can also upgrade most drivers that have never contained ferrofluid. The kits listed are approximate fill quantities relative to approximate voice coil diameters. In general, the air gap should be 75% filled prior to inserting a voice coil diaphragm assembly. The kit contains synthetic ester-based ferrofluids and in most cases should not pose any adhesive incompatibility. It is recommended that this is confirmed by contacting the driver manufacturer prior to usage. Adding ferrofluid to a driver not intended for it will, in most cases, void the original manufacturer's warranty. Included in kit: A ferrofluid packet, absorbent paper strips for removing old ferrofluid, detailed instructions, and material safety data sheet.
    If we knew the magnet and pole piece dimensions it could be calculated. You could measure the gap and dia. of the gap and depth of gap and get a pretty good idea. What is unknown is the I.D. of the magnet though.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Ah ok, yeah I didn't read all that initially. The video I watched the guy didn't need but what looked like half the packet is why I asked.
    xschop Posts: 5,333
    Are you guys sure he should even put ferrofluid in since the Wuhans are Kapton formers?
  • Gardenstater
    edited March 2022
    Me? Nope I'm not sure at all! :# Maybe we need to consult The Tale of 5 Tweeters author @DarqueKnight
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    pitdogg2 Posts: 27,213
    edited March 2022
    F1nut Posts: 51,934
    This isn't rocket science. You have a one inch tweeter, so you buy the version for a one tweeter. Fill up the cavity to about 75% full and throw the rest of the tube away. Repeat for the other tweeter.
    audioluvr Posts: 5,982
    Ferrofluid also helps to prevent coil burnouts. Unfortunately, as it ages, it tends to dampen too much.
  • I got it don't think I deserved some childish "duh" comment. Thanks.
    F1nut Posts: 51,934
    Have another taco.
  • I will, bet you haven't seen one in a while.
    F1nut Posts: 51,934
    Can't stand Mexican food.
  • Gardenstater
    I'm thinking a syringe and hypodermic needle may be helpful. Use whatever is the approved method for cleaning all the old stuff out and then fill it all the way up with the hypo/needle and then, since you know how much you put in, withdraw 25% of that and you should be in the ballpark.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    I've seen folks use a paper towel to soak it up out of the channel. If you're really industrious maybe an air compressor out side to blow it out. Wipe off and refill.
