Signa S2 audio delay problems
abreaks
I have my soundbar connected via HDMI ARC to a Visio TV. The audio lag is really obvious with massive lip syncing issues even with simple stereo audio streams off cable. With stored media I can fix the lip syncing issue with a +300ms time shift but that seems insanely high. I don’t see many options for a fix. Is this a situation unique to me? Should I try optical?
I have same issue!
I found this link very helpful on that issue:
https://www.popsci.com/story/diy/fix-audio-delay-soundbar-tv/
