Are people experimenting with SDA
I have the L800’s with the atmos modules. My speakers are 8’ apart (too far) so I don’t get a powerful SDA effect.
I’ve run the atmos speakers in conjunction with the SDA effect and it works great. Is it possible to configure these with a minidsp and delays to augment the SDA? Has anyone been experimenting with enhancing SDA?
Answers
  • TroyD
    TroyD Posts: 13,124
    I don't mean this to sound patronizing or anything.....but, make sure that the SDA cable is firmly connected.
    Ask me how I know this.
    Just saying, run through the basics first. Connections. Phasing etc...
  • tjcinnamon
    tjcinnamon Posts: 100
    edited March 2022
    TroyD wrote: »
    I can feel the cones moving and it’s darn hard to plug-in and unplug.
    I’m likely good there, correct?
    My seat is 9’ back so at 8’ apart it’s too far. However, I still get the effect for sure
    VR3 Posts: 29,388
    Sda needs side walls
  • tjcinnamon
    VR3 wrote: »
    I thought it was the opposite
    VR3 Posts: 29,388
    In my experience, sda speakers need side walls atleast 6ft on each side... Equal distance is better
    F1nut Posts: 51,674
    tjcinnamon wrote: »
    When I demoed them they were way more than 8 feet apart and got way more SDA than I cared for.
    What are you driving them with?
    FYI, the SDA drivers will move even if the SDA cable is disconnected due to the air pressure in the cabinet.
  • tjcinnamon
    edited March 2022
    tjcinnamon wrote: »
    Anthem MCA 325
    The way I tested was an REW sweep, I’d play the right speaker and have my hand on the left meaning that no signal was hitting the left speaker (outside of the sda driver)
    That said, I can triple make sure they sda cable is plugged into though. My guess is just push on it super hard?
    What were the sidewalls like when you demoed them? Mine are about 8’ from the side walls. Nearly equidistant
    F1nut Posts: 51,674
    IIRC, they were covered with black cloth curtains over sheet rock. The room was what I would call huge.
    treitz3 Posts: 19,945
    T
    tjcinnamon wrote: »
    VR3 wrote: »
    Not our observations at this year's Polkfest. On the long wall? "Shouty", no sound stage, no bass and in general? Well, they sounded like crap.
    We moved them the next day to the short wall and OMG, what a difference! They opened up, the SDA came into play, bass was there and as they opened up? (brand new speakers, never played before) The folks that listened went from thumbs down (kinda) to double thumbs up.
    All you have to do is read the Polkfest for this year. It's all documented.
    Documentation is just a guide. It's not a rule that must be strictly followed. Trust your ears on what sounds better. Always.
  • tjcinnamon
    treitz3 wrote: »
    T
    tjcinnamon wrote: »
    VR3 wrote: »
    Is this the thread? https://forum.polkaudio.com/discussion/194443/carolina-polkfest-vol-5-oct-22-24-2021-north-charleston-sc/p1
    I’ve been searching for it but can find the posts with the results
    My bad dude. It must have been on another thread. My apologies about that. The summation of our observations is pretty much wrapped up in the above statement though. If you look at the photos? On day one, we had them set up on the long wall. The next morning, we set them up on the short wall and they didn't move from that location for the rest of the event.
    The change was drastic and oh, so welcome. Like a completely different speaker kinda different.
  • tjcinnamon
    treitz3 wrote: »
    No worries and thank you for helping.
    By long wall, you mean far away side wall; and short wall means closer to a side wall.
    So if my speakers are 3' away from a side wall vs 8' away from a side wall then the long wall is 8' and short wall is 3', correct?
    Correct.
  • tjcinnamon
    treitz3 wrote: »
    Correct.
    Thanks for your help. I’ll post back what I find
  • tjcinnamon
    treitz3 wrote: »
    Just picked up some cardboard boxes to construct a fake wall. Those should reflect things above 400Hz.
    I’ll be constructing a make shift movable wall for testing!
  • tjcinnamon
    Okay, update: confirmed the phase using REW (in addition to looking at how things were plugged in); also confirmed SDA was running with REW
    The cardboard helped. Basically I made my room more symmetrical. I’m going to draw up something to post what I did.
  • tjcinnamon
    edited March 2022
    treitz3 wrote: »
    Do you think that absorption on the side wall is a good idea or a bad idea?
    F1nut Posts: 51,674
    Generally, an acoustic panel at the first reflection point is of benefit. Other than that, no.
    VR3 Posts: 29,388
    Those in the know wrap their entire room in heavy curtains to deaden the sound as much as possible. 😝🤯
  • tjcinnamon
    VR3 wrote: »
    I just ran some tests, I already had them there and SDA sounded slightly more pronounced with them on the wall. Given they are decorative, it was easier to leave them so.
    I do need to put up a fake wall. So the question is do I make that absorbative. Given I already have GIK treatments for the fabric it may make sense to just get the absorbstifr for decorative reason. I just don’t want to negatively impact it.
    VR3 wrote: »
    Yeah......no. Don't be a Danny.
  • tjcinnamon
    Im going to put insulation on my fake cardboard wall to see how it would sound. I have some that I used for some other experiments.
    VR3 Posts: 29,388
    treitz3 wrote: »
    VR3 wrote: »
    You just are not ready Tom. It's ok
  • tjcinnamon
    Update: it sounds fantastic with the insulation. Sorry for the mess
    edited March 2022
    Mess? We have all been there and done that.
    Try pulling the mains out from the back wall a tad....no toe in. These are NOT conventional speakers...
    nooshinjohn Posts: 25,877
    They need to come out at least a foot in that configuration
  • tjcinnamon
    edited March 2022
    treitz3 wrote: »
    Before the false wall (in cardboard on the right) the toe in made a huge difference. But it was a desperation move. I’ll try to straighten them tomorrow. I toed them in an inch at a time off that media console 6 inches in each direction. 4” seemed to give the best effect pre-wall
  • tjcinnamon
    I’ll give it a shot but why do you say that?
    tjcinnamon wrote: »
    Because the front baffles of the speakers should not be behind the plane of any walls, equipment racks or other obstructions. The picture looks like the speaker to the right is at least 6 inches behind the wall and it is also corner loaded which is not good.
    F1nut Posts: 51,674
    You cannot toe in SDA speakers, period.
    The right speaker crammed into that corner is a no go.
