Are people experimenting with SDA
Answers
    nooshinjohn Posts: 25,964
    edited March 2022
    Too bad you can’t flip the room and put everything where the sectional is... or better yet, on the short wall where the glass block window is.
  • tjcinnamon
    tjcinnamon Posts: 100
    tjcinnamon wrote: »
    They need to come out at least a foot in that configuration
    I’ll give it a shot but why do you say that?
    Because the front baffles of the speakers should not be behind the plane of any walls, equipment racks or other obstructions. The picture looks like the speaker to the right is at least 6 inches behind the wall and it is also corner loaded which is not good.
    That makes sense. The baffle is about 1” behind that wall and there’s a few inch gap in between. I can pull it out to make it where the baffle is in front of that wall by 2”.
  • tjcinnamon
    No doubt!
    tjcinnamon wrote: »
    tjcinnamon wrote: »
    Whatever you do on the right must be done to the left. If you are 12 inches off the back wall on the right, that is how much you need on the left.
  • Emlyn
    Emlyn Posts: 4,796
    edited March 2022
    Traditional stereo speakers could work better in that space but it can be optimized as much as possible for the L800s. They won't sound as good as they could though. The Atmos modules are not an issue however. All they do is add height by bouncing sound effects from the ceiling, not width.
    F1nut Posts: 51,912
    The glass block wall is far too short. SDA needs a minimum 15 foot wall.
  • tjcinnamon
    Baffler
    tjcinnamon wrote: »
    tjcinnamon wrote: »
    That's what I did. I did some testing pulling it out and straightforward vs angling just a touch. Slightly angling sounded better from an SDA perspective (although it's less angled than before). That fake side wall (of insulation) made a world of difference. I'm going to continue to experiment though.
    About 6 months ago I met with Accoustician Mathew Poes, he suggested based on my room, to angel it. His review on the L800's was stellar and convinced me to purchase them.
    If I can run them straightforward as intended, that's my goal.
    F1nut Posts: 51,912
    I'm sorry (not really), but you got bad advice. He should have told you to put them on the opposite wall with no toe in.
  • tjcinnamon
    I didn’t have a choice on the wall because me existing speakers and TV were already set up, my atmos and surrounds are in wall, and the sectional is larger than that wall.
    The toe in was a last resort. It makes sense if the speakers are 8’ apart and listening position is 8’ back.
    Polk also suggests having a far side wall and yet people are saying closer to the side walls is better in some threads on here.
    I dont think it was bad advice all things considered.
  • tjcinnamon
    Emlyn wrote: »
    They work pretty good, especially with my new fiberglass side wall :)
    For my next theater, I can design it with these in mind up front
    VR3 Posts: 29,514
    No one said you needed near or far side walls. I just said you need side walls.
    If your side walls are 15 ft (+) away... you basically dont have side walls as your first reflection points would be like the back corners of the room and you have a whole host of other things to combat.
    At Troys, his were like 9 to 12 ft on the right and 20 plus feet on the left.
    If your side wall is 6 to 8 ft away, that is a far side wall and should work fine.
  • tjcinnamon
    VR3 wrote: »
    Yeah, they are between 6 and 8. I’ll recalibrate without the toe in and see how it makes a difference but I think I squeezed all I could out of this room.
    Overall I’m very very happy with the improvement. That side wall moved it from Good to Great.
    Curious how Dirac will treat other members. It’s been finicky for me
    Seriously... drop the toe in.
    F1nut Posts: 51,912
    I've been playing with SDA speakers for 38 years. NO toe in is rule number one for set up.
  • tjcinnamon
    Should the sidewalls have absorption or no? They are approx 8’ away
  • SIHAB
    SIHAB Posts: 5,526
    I played with SDA in my youth. B)
    F1nut Posts: 51,912
    tjcinnamon wrote: »
    I believe the only correct answer is it depends.
  • tjcinnamon
    tjcinnamon wrote: »
    I'll experiment and see!
    F1nut Posts: 51,912
    tjcinnamon wrote: »
    tjcinnamon wrote: »
    No doubt, you've got a tough room. Just a thought, maybe install some sort of expandable pull out fake wall to entirely close up that opening leading back to your office area. SDA likes symmetry.
  • motorstereo
    motorstereo Posts: 2,359
    [/quote]
    I believe the only correct answer is it depends. [/quote]
    [/quote]
    Sidewall treatments worked wonders for me. But they are 1.2tls with walls about 3' away.
    edited March 2022
    No doubt, you've got a tough room. SDA likes symmetry.
    SDA thrive on symmetry. I have yet to hear them work as the should in any setting that did not allow for that. I believe the original SDA are more forgiving of room shortcomings, but the L800 are a completely different speaker.
    In the OP’s setup, the L600 would have been the better choice, IMHO...
  • tjcinnamon
    tjcinnamon wrote: »
    tjcinnamon wrote: »
    tjcinnamon wrote: »
    Great idea! I plan on more or less doing that with that cardboard insulation wall which I'm going to have change out with freestanding GIK room treatments. The options are 2" and 4", based on their graphs I can't tell if the 4" do less absorption up top vs the 2".
    https://www.gikacoustics.com/product/freestand-acoustic-panel-gobo/
    https://www.gikacoustics.com/product/freestand-bass-trap/
    F1nut Posts: 51,912
    Honestly, I think you'd be better off starting with a solid fake wall. You've already got more than enough acoustic damping on the wall above the sofa. You've got to let the music fill the room. Too much damping will suck the life out of it.
  • Hermitism
    Hermitism Posts: 4,329
    edited March 2022
  • BlueFox
    BlueFox Posts: 15,250
    I would be apprehensive about having to add partitions to make my stereo properly work. It bugs me just having to play the right channel a bit higher to get a good balance. But, to each, their own.
  • tjcinnamon
    BlueFox wrote: »
    I know what you mean. The good news is that I’m at about 80% of SDA compared to what I heard in the store. Before I put this fake wall of cardboard/insulation I had the effect too.
    I’m definitely going to put a block up because it enhances the effect. I certainly have concern about being over dampened.
  • Hansvelton
    Hansvelton Posts: 151
    edited March 2022
    Here, I was told you invented SDA??
    (Joke),
    But you are correct, they need to be "just right" or else it throws off the image and the whole thing "collapses". A tough room for sure, going by the pictures.
  • Hansvelton
    Everything has to be equal and symmetrical with SDA. At both the speaker and listening end.
    Probably the one really bad thing, is placing them in a room that is not optimum.
  • invalid
    invalid Posts: 1,509
    Those office cubicles are very sound absorbing.
