WTB parasound HCA-600
Mr. Sharpe
Looking for a couple or maybe just one for now. Hopefully near mint and possibly rackmount version, either doesn’t matter. Going back to separates for my HT.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
**EDIT**I’m actually any small to mid sized multi channel amp, preferably 5-7 channels possibly 3. I was hoping for another parasound but all their multi’s are waaaay too big and more power and girth than I need. I’d consider some of the emotiva basX line which are small, affordable and feature packed. And Adcom has come out with so many different models like the 6006, 7605, 7300, 7400, 2535, 6000 etc. I’m leaning that way. Gotten to where 12v triggers dont matter much but honestly is needed although could be maybe be added if needed. ThanksHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
Mr. Sharpe wrote: »**EDIT**Gotten to where 12v triggers dont matter much but honestly is needed although could be maybe be added if needed. Thanks
Something similar to this works well for my Parasound HCA-1500A.
Tripp Lite 8 Outlet (5 Energy Saving) Surge Protector Power Strip, 8ft Cord, Right-Angle Plug, Lifetime Limited Warranty & $150,000 INSURANCE (TLP808NETG) Grey https://www.amazon.com/dp/B003A7P262/ref=cm_sw_r_apan_glt_i_2R4KEANM9PYXVGBPCC5D -
Tripp lite makes a good one too. My system is a dual purpose one, I currently have a denon receiver powering my center and surrounds and Parasound P6 bypass for my fronts powered by the same amp.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
5ch McCormack available here: https://forum.polkaudio.com/discussion/196098/items-for-sale
That looks too big, heard nothing but good things about McCormack though😉 maybe I just need to break down and rebuild my tv stand taller lol I’ve been threatening to😁 I’ve just got a fever to do somethingHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Would ya consider a 5 X 100WPC THX certified Rotel RB-985? You may find the original FS ad elsewhere on this forum.
For a few extra $ I can add a Furman Miniport - just needs a relay
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
That sounds cool. I’ll read up about it. 🙏Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I ended up getting an hca-750 instead of the 600.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Better choice with the HCA-750. I had refurbished a HCA-800ii and an HCA-1000A. The HCA-800ii had several caps go out of spec. The 1000A were all still in spec. Plus, I believe the 750 was a John Curl design, not so for the 600.Stan
Main 2ch:
HT:
Other stuff:
It’s a good amp and it is a curl design. It’s nice amp and sounds really awesome. I’m hoping to get another for my surrounds sometime then a processor but one step at a time lol. I felt like getting a 1000 but at that point is overdoing it power wise. I hooked my rta’s to it and it sounded great. I didn’t really push it or anything, more or less just making sure it worked.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
HCA-750 a John Curl design? No mention of that in the first link…
https://parasound.com/vintage/hca750a.php
This links mentions John Curl and design in the same place
https://parasound.com/vintage/hca1000a.php The 1000*power specs 110 WPC into 8 ohms, of course higher into 4 ohms etc etc
*two features of the “a:” makes more power and has a 12VDC trigger connection. A PS Cap refresh can mitigate the power differences.
I agree the 750 specs out well, good for speakers of average to above average sensitivity. More complex loads or higher volumes may challenge it.
Tony.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Ok the 750 design was only influenced by John Curl, it doesn’t say it was designed by him.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Ok, I may have misspoken about the 750a being a John Curl design. The internals look nearly identical to the 1000A that was designed by Mr. Curl but scaled back. None the less, it is a nice little amp.
John Curl has said on another forum that the HCA-1000(A) was not one of his best designs because it was constrained by the size of the cabinet and had to make compromises. He used the largest PS caps that he could get at the time and that would fit in the low profile cabinet. There are better caps available now that do fit. I was able to upgrade mine and also got some information on biasing the amp beyond the factory settings. It was based on temperature rather than a specific voltage. This does require keeping the amp well ventilated.Stan
Main 2ch:
HT:
Other stuff:
That’s interesting. You’re right the internals look the same to me too. Oh man I’m sure capacitor sizes have gone through leaps and bounds since the amp came out😁
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
My turn to misspeak: did you author a DIYaudio thread for cap refreshing and an add’l tweak or two? JC chimes in on some details or that’s another Polkie.Ok, I may have misspoken about the 750a being a John Curl design. The internals look nearly identical to the 1000A that was designed by Mr. Curl but scaled back. None the less, it is a nice little amp.
Anyway here’s some links to that end that collected while had a pair in my system:
https://forum.audiogon.com/discussions/parasound-hca-1000a-modifications?highlight=parasound+hca-1000a
https://elektrotanya.com/parasound_hca-1000a.pdf/download.html
http://www.diyaudio.com/forums/solid-state/245360-parasound-hca-1000-power-switch.html
http://www.diyaudio.com/forums/power-supplies/275194-power-supply-caps-standard-vs-audio-2.html
http://www.diyaudio.com/forums/solid-state/309046-parasound-hca-1000-upgrade.html
http://www.diyaudio.com/forums/solid-state/274906-parasound-hca-1000a-refresh.html
http://www.diyaudio.com/forums/solid-state/243682-hca-1000-repairing-left-channel.html
Enjoy Mr SharpSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Yep. I was on DIYAUDIO and Mr JC chimed in and gave me some good advise. I would think that it would apply to the HCA-750A too if you are that adventurous.
I did recap the HCA-1000A and the HCA-800ii. The biggest difference going with higher quality caps was the background had much lower noise, very dark in a good way,Stan
Main 2ch:
HT:
Other stuff:
I am, but today I was thinking today to hold out for another 1205 for my ht. There’s a rack mount one on eBay right now that would loo super cool next to my rack mount 1500! but I do t have the cash to get it. If I could get one I’d let the 750 go pretty quick so I’d be waiting on doing any mods on it.
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
A Cap refresh is more than a mod. It is to an amp is as essential as oil change to a car. Even if they appear ok, over time they go out of specMr. Sharpe wrote: »If I could get one I’d let the 750 go pretty quick so I’d be waiting on doing any mods on it.
A 1205 is slightly more than a 5 ch HCA-1000A.
Rock on regardless. Tony
Then I may need to step on it then;)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
