Polk LSiM 703 or R900 for Height Speakers 7.2.4
mpitogo
mpitogo Posts: 520
edited March 2022 in Speakers
See signature for media room theater equipment. I'm torn which direction to go. I read LSiM 703 are heavy and a PITA to wall mount. Atmos/DTS-X/Auro-3D.
  • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
  • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
  • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
  • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
  • Office-2.1 B&W Formation Duo and Bass
  • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
  • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
  • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
  • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
  • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
  • Maintenance: Pro-Ject VC-S Record Cleaning Machine
Sign in to vote!
This is a public poll: others will see what you voted for.
  • mpitogo
    mpitogo Posts: 520
    edited March 2022
    LSiM 703 two pairs
    breaking it in
  • mpitogo
    mpitogo Posts: 520
    LSiM 703 two pairs
    Temporary PM-10 for 2.0 setup with airplay
  • mpitogo
    mpitogo Posts: 520
    edited April 2022
    LSiM 703 two pairs
    Slowly getting stuff in place.
  • Emlyn
    Emlyn Posts: 4,786
    R900 two pairs
    Mighty impressive looking!
    Only suggestion/question is would the rear speakers perform better if they're even with the rear heights? Meaning, away from the side walls about a foot or two?
    My guess there's a good reason you put them where they are.
  • mpitogo
    mpitogo Posts: 520
    LSiM 703 two pairs
    Hi Emelyn,
    Thanks. Per polk manual it’s the recommended orientation, the mid and tweeter drivers are side firing so with them at the far corners the drivers are firing into the MLP. The directivity would be affected if I moved them close into the room, as surround backs I think the 703 would be better suited. I don’t have amps yet (was ordered and in production) so listening demos will have to wait a bit till I would know.s-l640.jpg
  • Emlyn
    Emlyn Posts: 4,786
    edited April 2022
    R900 two pairs
    Makes good sense. I'd forgotten the driver configuration on those was like that with essentially no sound coming out one side of the cabinet.
    I was also thinking a pair of 703s could serve well as rear surrounds. I've had both models in that position and preferred the 703s but they were close and I have another pair of 703s as side surrounds. I figure it's best to have all four the same model in those positions.
    I think you'll be extremely impressed with those front and rear height speakers for Atmos.
    F1nut Posts: 51,885
    That's a small space for all those speakers.
  • WLDock
    WLDock Posts: 3,073
    I'm wondering if its a dedicated built space with Green Glue between drywall layers or made with factory damped Gypsum? I can't tell the lengths but it looks to be about 12 ft. wide. The 7.2.4 sides are a little close to the rears. No doubt a 5.2.4 would have been more than fine.
    That system is going to light that space up! (and maybe the house?) Should be able to get some good pressurization going on. It should be a very intimate experience! Should be fun!
  • mpitogo
    mpitogo Posts: 520
    LSiM 703 two pairs
    12.5W x 20L x 10H
    Unfortunately the walls are not green glued or dampened, I will need to put up more acoustic treatments. I tested the heights running full range and the cabinet vibration travels through the speaker mount into the studs. Hopefully not an issue when crossed over at 80hz.
    Two rows of 3 chairs are coming in this Wednesday.
  • what type/brand mounts are those that you are using for the 703's?
  • eclypse
    eclypse Posts: 595
    I was gona ask the same question.. attaching a mount to the plastic like that.. it held up? Heavy speaker.. if so I'd like to know what mount you used cause I'm debating having mine as height channels.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • mpitogo
    mpitogo Posts: 520
    LSiM 703 two pairs
    The mount's are screwed through the plastic down to the wood. I've had no issues with them hanging up almost 2 years now. I was thinking of upgrading the attachment with T-nuts on the inside and switching to machine screws with standoffs.
  • Geoff4rfc
    Geoff4rfc Posts: 2,893
    mpitogo wrote: »
    Well, I think it's probably time for some finished pics.....you had me at "two rows of 3...". And maybe a rundown of your finished theater.....and your thoughts on it's performance since completion.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
