Adding an Equalizer to an Integrated Amp
Answers
Amazon basics is CCA which isn't ideal. Are these the same cables you were using with your previous amp? Also can you post a photo of the rear of the M5si so we can see the connections?
Well you'd ideally have an integrated with a balance control. Or you could try adjusting it from the source. But yeah most competent EQs don't have balance control IIRC.
They are the same cables, but I am totally willing to invest in better ones.
The RCA cables in the CD inputs were for the bluetooth but I don't actually use that. Just the phono and turner unputs.
Thanks for the pics! Interesting banana plugs on those cables.
I was thinking that another thing you could try is plugging in an A-B USB cable from a laptop to the USB input on the rear there. Then you'd be able to try the internal DAC and perhaps that offers better audio quality. -
Haha I don't recall where I got them from.
I do have a custom built computer in the office, so I suppose I could probably plug that into the amp since all my music is on there anyway.
I know people hate this, but I honestly think the phone can do better than it is. As I mentioned with headphones and in my vehicle (with aftermarket Morel Tempo components) I have no issues with the sound from the phone at all. -
Well I'm not saying it would automatically fix the issue you're experiencing, but it would be in an interesting data point/observation to hear how the internal DAC sounds vs the iPhone dongle.
Do you have a Spotify or Tidal account? What volumes do you typically listen at? -
I do use Spotify, but mostly I listen through my music app. I rip CDs to iTunes and transfer the songs to the phone.
Also isn't the amp going to overheat and maybe even damage the TT with it sitting directly on top like that? Most manufacturers recommend at least 3-4" clearance above the vents in order to ensure the component has a means to exhaust it's heat.
Not trying to overly critique and pick apart your setup, just trying to look out for your investments.
Edit: From the user manual:
Try out my bass-heavy test tracks playlist and see if this gets those woofers moving: https://spoti.fi/3LJs9r4 -
Good to know I will adjust that now. -
AIFF format? -
Apple Lossless, 16 or 24 bit depending on the source. -
Haha thanks I will!
Edit - Hm says page not found on my end -
Joining back in....those speaker cables have got to go. Cables, including RCA's are an important part of a quality audio rig. Look around at the various audio retailers to see what is out there, then read the reviews. After that look around for used cables. There is a business called The Cable Company, where you can buy used cables and if you don't like them you can return them for which they will charge you 10% of the asking price. It's not a bad way to try various cables.
Another possibility is to see if there are any audio nuts close to you that might bring over some quality cables to demo.Political Correctness'.........defined
President of Club Polk -
Another thought, is the MF on a dedicated 20 amp line or is it on a shared 15 amp line? Is it plugged straight into the wall or some sort of power conditioner?Political Correctness'.........defined
Hey baby, you wanna demo my cable?? *wink* -
I will try it out!Joining back in....those speaker cables have got to go. Cables, including RCA's are an important part of a quality audio rig. Look around at the various audio retailers to see what is out there, then read the reviews. After that look around for used cables. There is a business called The Cable Company, where you can buy used cables and if you don't like them you can return them for which they will charge you 10% of the asking price. It's not a bad way to try various cables.
Thank you both for all your advice! I will definitely change the cables, my next investment!
It’s plugged into a power bar.
Sadly not the first time I’d have been asked.
Plug it straight into the wall. If you don't have a dedicated 20 amp line feeding it, consider getting one installed. It makes a difference.Political Correctness'.........defined
If you don't do anything else? Plug that into the wall outlet directly.
Ok! Thank you again!
Get a RARE Vintage AudioControl Model C-101 Octave Equalizer Spectrum Analyzer TESTED it's on eBay .I had one very good eq
Still won't adjust the balance.
It sounds counterintuitive but when you move to an integrated amp like this with less distortion, sometimes the bass can sound more lean & tight as opposed to loose and boomey.
What you might be hearing is not "less bass" but rather a higher quality low end reproduction based on the M5si's grip on the woofers.
^THIS^
I know hindsight is 20/20, but maybe this will help someone else out.
Before you purchase any piece of equipment, make a checklist of the features that you need/want and prioritize them.
There are integrated amps that have tone controls, balance, and loudness controls.
Some of them are Luxman, Marantz, Denon, Parasound, and others.
The MF should not have been on your short list.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I don’t regret my decision, but thanks man super helpful! -
Maybe simply pushing the speakers closer to the wall will get you the loose sound you want.That could very well be the case. Maybe I like the loose sound? It wouldn't say the bass is missing from the music so that seems plausible. I've been playing mostly rock, hard rock, some leaning more to metal, and some a bit more symphonic. Some songs seem to produce better results than others, so it also comes down to the recoding/mixing in some cases.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Have you checked the settings on the eq built into your phone?
Good call. Check Settings -> Music -> EQ and see what it's set to.
