Will I notice the difference If I add a 2nd Sub?
I have Polk Signiture series 5.1 system. Will I notice a difference if I add a 2nd Subwoofer?
    F1nut Posts: 51,674
    Probably
  • polkevin
    polkevin Posts: 17
    Yes! I didn’t think it would but I got a good price on a used sub and figured why not try it as a second. Really rounded out the bass.
    VR3 Posts: 29,386
    Minimum 8
    pitdogg2 Posts: 26,927
    VR3 wrote: »
    Minimum 8
    Is that the new Radio Shack "realistic" series?
    polkevin wrote: »
    Yes I personally feel two should be the minimum in a room. Ymmv but I have found if you can get them in opposite corners they really compliment each other.
  • ken brydson
    ken brydson Posts: 8,980
    polkevin wrote: »
    While I mostly agree with you Ivan it depends on the sub IMO. One quality sub will easily outperform 2 mediocre ones. The OP did not mention what his current sub was...
    VR3 Posts: 29,386
    Yes, 8 of the minimus 7 crossed at 80hz will bring the thunder
    polkevin wrote: »
    Ken,
    Even with quality subs I feel two smoothes (evens) out the room response so not to overwhelm an area.
    That has been my experience, and why I said ymmv. I've not been in every room lol.
    I've been in some rooms with one great sub and different seats can have vastly different responses from the sub.
  • ken brydson
    polkevin wrote: »
    Ken,
    In total agreement Ivan. All I was saying without knowing what sub the OP is currently running it's hard to say. Adding another PSW10 (for example) to have duals vs a capable SVS, HSU, REL, Velo....
  • jbreezy5
    jbreezy5 Posts: 1,141
    2 subs = In-room Balance, Daniel son.
  • vader540is
    vader540is Posts: 191
    Get a Umik-1 and REW it will help with placement on your 2nd subwoofer which will help reduce nulls.
  • pearsall001
    pearsall001 Posts: 5,224
    edited March 2022
    I was always a big believer in the 2 sub scenerio. However now that I've had my KEF KC62 for a few months now my thought process has done a complete 180 reverse.
    Due to it's size (or lack there of) & being able to move it around to endless room placements has really given me pause about another. My room is 3k cubic feet & the single KC62 has done wonders.
  • Hansvelton
    Hansvelton Posts: 151
    VR3 wrote: »
    I am still waiting for your Minimus 7 crossover mod, you know the one that is 3 times bigger than the speaker itself... ;)
  • rooftop59
    rooftop59 Posts: 8,121
    winterpeg wrote: »
    So many variables…what sub do you have now, what will you add, how big is your room, where is your sub currently, what AVR and room correction software are you currently using, etc.
    Game Room 5.1.4:
    Bedroom 2.1
  • gp4jesus
    gp4jesus Posts: 2,016
    The more the merrier.
    Seriously yes but… more “fair” subs will do little to smooth and improve your bass QUALITY
    *all connected w/Premiere ICs
