Equipment cover?
Any recommendations on equipment coverings? If that's even the correct term.
Have a few pieces I'd like to cover to keep the level of physical cleaning to a minimum. Not really wanting the large plexi statement cover types, cost and ease of use are also a priority.
What say you?
Dave
What say you?
Dave
Once again we meet at last.
I have digital deck covers for my speakers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A fine-finished satin(y) cloth (could be real silk or polyester) makes a nice cover, IMO.
Way back when, an old hifi buddy covered his Nak 600 cassette deck (a slope-decked toploader in its default configuration) with a piece of satiny black fabric. Quite nice, thought I then (and, in my mind's eye, at least, still now).
Thanks for the suggestions, the website looks like the way. Will have to search through for sizes, my stuff isn't listed.
I throw a microfiber cloth over some stuff, but it does move around and fall at times. Wanting something a but more purposeful.
DaveOnce again we meet at last. -
the covers work great on rectangular equipment, not so good on tube equipment.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
https://radiodustcovers.com/Hi-FiAudio.html
Been meaning to get covers for all my gear, but I am a huge procrastinator. I believe a couple Polkies have bought from this guy. @SCompRacer comes to mind, IIRC.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
That's the place. Radio Dust Covers is w6on on ebay.
https://www.ebay.com/usr/w6on?_trksid=p2047675.m3561.l2559
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Here is another.
I have it save to buy one for my Oppo. I've contacted them to make one for my Aragon amp as well. Price was $5 more than the Oppo.
https://www.ebay.com/itm/163556335645 -
I'm a practical kind of guy. Some oversized microfiber towels get the job done for me. As an added bonus, you can use them to dust off your gear...
Don't let it sit...
If you use it...you won't have to cover it2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Don't let it sit...
Your house... must be way less dusty than my house.
But then again you "older" folks shed lots of skin particles.
More than likely forced air heating/cooling. Steam heated houses have a fraction of the dust generated by forced air...Remember, when you're running from something, you're running to something...-me
I've lived in both, didn't notice any difference. -
Until recently this house was a mix of radiant and traditional hot-water baseboard heat.
It is now augmented with some high-effiency heat pumps as we slowly edge away from hydrocarbon combustion
That said, the dust hasn't changed -- we live on a dirt road. Dust is pretty endemic around these parts.
Me too, and did. Weird, must be where one lives!Remember, when you're running from something, you're running to something...-me -
So how well do these cover the backsides of your gear with cables sticking out? Currently interested in one for the Oppo and my Parasound A31.Home Theater
I've found that they don't cover the cables sticking out, if they are sized to match the equipment. I ordered mine 2" longer, depth wise, to cover everything. You could cut the back side to make a flap that would hang over the cables. I did that to one of mine, still works...Remember, when you're running from something, you're running to something...-me
Some the back has a flap that is not sewn on the sides to allow room for wires.
Mine has a flap on the back. No siren goes off when you lift it though, like the one the ladies would lift on the Indian statue in that tavern by Fox Lake 50 years ago. (They would lift the front flap).Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
@smglbrth has good advice about maybe needing longer covers. If you use aftermarket feet, pads, etc., then even if they have a cover for your specific piece of equipment, it may not be tall enough. I use DigitalDeckCovers like others recommended.
