Signa 2 soundbar muffled
amyps222
amyps222 Posts: 3
edited January 2022 in Troubleshooting
I just bought the signa 2 soundbar to hook up to LG TV. It sounds great, but sometimes sounds really muffled when I switch to a different LG channel or a song change in amazom music. I switch channel or forward song then go back, and it's fine. Do I need to return this for another, or is there a solution for this.
Answers
  • SeleniumFalcon
    It's doubtful the soundbar is the cause, it doesn't know what program you've chosen. It simply plays whatever is given to it.
  • amyps222
    But if it's the same program (say, prime music) and one song is fine then the next song you can barely hear, any idea how to fix that?
  • SeleniumFalcon
    What settings on the Polk remote are you using?
  • amyps222
    amyps222 Posts: 3
    edited January 2022
    It's on music. It just happened again when a new song came on. I switched it to movies and it was fine. Switched again back to music and it was still okay. So, I don't want to have to do that switching back and forth every time it happens.
  • SeleniumFalcon
    That's very strange, I would recommend sending an email to: Kim.Jasper@soundunited.com and explain what's happening.
