Anyone know where I could find some polk sda srs 1.2tl speaker grills
Vintage speakers
Answers
    Toolfan66 Posts: 18,068
    That is going to be a tough find, would be easier to make yourself (if you have the skills and tools of course) or have them made from a local wood shop, you could put the grill cloth on yourself, that is the easy part..
    nooshinjohn Posts: 25,929
    ... Finding the SDA-SRS badges to put on them... not so much.
  • JayCee
    JayCee Posts: 1,509
    edited January 2022
    I have a pair of SDA-SRS (non 1.2) grills I've wanted to find a home for. Never have tried them on my 1.2tl's but assume they would fit. @1picasso...where are you located?
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    F1nut Posts: 51,787
    edited January 2022
    JayCee wrote: »
    They are a different size. The 1.2TL is 3/4" wider than the SRS.
  • JayCee
    JayCee Posts: 1,509
    edited January 2022
    Cool, now I know. Had them for 10 years and never checked. So, anyone needing SRS grills (non 1.2) hit me up.
    Edit to add...I'm located in the Pacific Northwest and often/willing to travel a reasonable distance.
    Post edited by JayCee on
    I don't like the badges on mine, I like the shaved look better, I have my set in a box somewhere..
    JayCee wrote: »
    Learn something everyday!!
    F1nut Posts: 51,787
    JayCee wrote: »
    Try them anyway, my info could be wrong.
    pitdogg2 Posts: 27,059
    Yep I'd try them for giggles. A little shave here and there they may work for someone who has none.
  • ken brydson
    ken brydson Posts: 9,005
    Joke in there someplace...
    txcoastal1 Posts: 13,513
    edited January 2022
    as long as you don't hear banjos playing :#
  • JayCee
    JayCee Posts: 1,509
    edited January 2022
    I'm renovating my basement and they're not accessible ATM, but I'll try them when I can and report back.
    I have the badges for them, too, but not part of the deal if they do move on.
    JayCee wrote: »
    We don’ need no stinkin’ badges...
    edited January 2022
    I was counting on you man ...
    I thought that was a good alley oop...
  • ptrooper
    ptrooper Posts: 501
    I just I Just compared my 1.2's and SRS's covers and can report back that they are exactly the same size ie, completely interchangeable!
    F1nut Posts: 51,787
    edited January 2022
    The 1.2 and SRS are the same size. It's the 1.2TL that is supposed to be 3/4" wider.
    Nope, the caps are the same size, that I do know..
    F1nut Posts: 51,787
    Then the SDA Handbook info is wrong.
