Anyone know where I could find some polk sda srs 1.2tl speaker grills
1picasso
Answers
That is going to be a tough find, would be easier to make yourself (if you have the skills and tools of course) or have them made from a local wood shop, you could put the grill cloth on yourself, that is the easy part..
... Finding the SDA-SRS badges to put on them... not so much.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have a pair of SDA-SRS (non 1.2) grills I've wanted to find a home for. Never have tried them on my 1.2tl's but assume they would fit. @1picasso...where are you located?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
They are a different size. The 1.2TL is 3/4" wider than the SRS.Political Correctness'.........defined
President of Club Polk -
Cool, now I know. Had them for 10 years and never checked. So, anyone needing SRS grills (non 1.2) hit me up.
Edit to add...I'm located in the Pacific Northwest and often/willing to travel a reasonable distance.Post edited by JayCee on➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
nooshinjohn wrote: »... Finding the SDA-SRS badges to put on them... not so much.
I don't like the badges on mine, I like the shaved look better, I have my set in a box somewhere.. -
Learn something everyday!! -
Try them anyway, my info could be wrong.Political Correctness'.........defined
Yep I'd try them for giggles. A little shave here and there they may work for someone who has none.
Joke in there someplace...
I'm renovating my basement and they're not accessible ATM, but I'll try them when I can and report back.
I have the badges for them, too, but not part of the deal if they do move on.nooshinjohn wrote: »... Finding the SDA-SRS badges to put on them... not so much.
We don’ need no stinkin’ badges...
I just I Just compared my 1.2's and SRS's covers and can report back that they are exactly the same size ie, completely interchangeable!
The 1.2 and SRS are the same size. It's the 1.2TL that is supposed to be 3/4" wider.Political Correctness'.........defined
Nope, the caps are the same size, that I do know..
Then the SDA Handbook info is wrong.Political Correctness'.........defined
