Dust Covers for unused ports
EndersShadow
First I’d like to thank @Rick88 for sending me down the rabbit hole of covering unused ports
Since purchasing some of those Red and White RCA silicone dust covers from him I’ve continued to buy covers for used ports to either try and reduce noise, or just keep them from getting filled with dust.
For my more important gear I bought these RCA covers, as well as these balanced in and balanced out covers.
For my cheaper stuff I still use Ricks covers.
Main reason for this post was to point out some additional covers I stumbled across.
Adafruit sells covers for USB A, also USB C (not linked), Ethernet and HDMI ports. They are stupid cheap so stock up and go wild.
I bought a few packs of each and they work well and blend in nicely.
Im am counting my unused RCA jacks already to order me some....looks like 28. Thanks!
On the hunt for diamond encrusted and cryo treated, quantum charged- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
FWIW I was told these are the Cardas ones just without the branding of course lol…"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Of course you are..... -
Tks, need me some of those..
I've got a good sized baggie of the silicone red and whites that I got from Rick as well. Never got around to using them. Free karma to anyone that wants them.
ken brydson wrote: »I've got a good sized baggie of the silicone red and whites that I got from Rick as well. Never got around to using them. Free karma to anyone that wants them.
I'll take them if you let me pay shipping. -
PM me your info. Shipping should only be a couple bucks, not worried about that. -
So what should you use, RCA condoms or shorting plugs? I'd assume shorting plugs on inputs.
EndersShadow wrote: »
Those are most definitely not Cardas.Political Correctness'.........defined
President of Club Polk -
@F1nut …. They look remarkable close….. but I’m not going to do a ton of research to verify one way or the other lol…
They work and do what they are supposed to so I got no complaints.
The XLRs are also quite nice and heavy."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The Cardas ones are 5 bucks a pop on Amazon. Plus I found a guy on the Emotiva forum that will cryo treat them for only an additional 5 bucks a pop. Darnitt.....wonder if I can return my Ebay ones!?!
Link to Amazon Cardas ones lol…"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
https://www.amazon.com/Stopper-Protective-protects-unwanted-interference/dp/B00UXS470S
https://www.amazon.com/AudioQuest-RCA-Noise-Stopper-Caps-pack/dp/B00447ZOCE/ref=pd_lpo_2?pd_rd_i=B00447ZOCE&psc=1
These are only $14 each
https://www.musicdirect.com/accessories/isoclean-rca-caps-set-of-10?gclid=CjwKCAiArOqOBhBmEiwAsgeLmXLWDF7gpzXHvDheQ_ZM_EOSH5L8ipsnARsBjl2Vq89gc-_kDWIsAhoC_I8QAvD_BwE2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yes, but my covers will have provenance because they were owned by the great Ken Brydson and Rick88.
@txcoastal1 thise Cardas show as 19.90 + 4.67 shipping…
I’m trying to find the 5.00 ones @kevhead72 is talking about lol…"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »@txcoastal1 thise Cardas show as 19.90 + 4.67 shipping…
If you divide by 4 = $5...
EndersShadow wrote: »@F1nut …. They look remarkable close….. but I’m not going to do a ton of research to verify one way or the other lol…
They are similar in design, but not in construction. The ones in your link are an Apollo AV in house design.Political Correctness'.........defined
But is a Cardas @ $5ea. Going to be any better than the Apollo @ $0.80ea ? I don’t really know what the material or construction difference is between the two.
Edit:
Apollo is Teflon Nickel Plated..
Cardas is Billet Brass Nickel Plated..
So the Cardas would be better built, and definitely feel hefty compared to the Apollo. So the question really is, is there a performance difference or are they just a dust cap??
Here is a 50pk of Apollo AV for $40
https://www.ebay.com/itm/400813863894 -
Nickel plated Teflon...?!?
Here is what I found,
So it is Nickel Plated Brass as well with Teflon Insulation PTFE..
Body - nickel plated brass
Insulation - PTFE (Teflon) for superior noise rejection
ROHS compliant - yes
Made in Taiwan
I went off the description in the ad, my bad.. 😃
So it makes the price of the Apollo’s look a lot better.. -
ahh, Teflon insulation
That's cool.
FWIW, while all of these these plugs are nice, in the absence of an electrical connection with the center ("hot") conductor, I don't see how they help with any sort of RFI or other electrical noise rejection. Shorting plugs would, but any of them that are just caps shouldn't short an "RCA" style jack, by design (of the jack).
Lmao cryo treated ......
Yea buddy omg still lmao 🤣😂🤣😂
I bought a bunch of Cardas caps a long time ago. They were more like a buck, maybe two each. The Apollo caps weren't available back then.
I would say they are similar materials and do the same thing.Political Correctness'.........defined
That’s actually what I bought. Need to buy some more as I ran out.
Wish they had larger sets of the XLRs
If I'm not mistaken, if you send those caps to F1 he will for an additional $5 give it the Royal Dingus treatment (pat.pending)Sal Palooza -
I picked some up for the hell of it, I agree on the XLR's..
I wonder how many they sold in the last couple days because of this thread. LOL!! -
I got the ones I got from Rick on my Vincent preamp for keeping the dust out, however those Apollo ones for the price might be worth checking out or maybe splurge for the Cardas ones. I also question how they would help with electrical noise, wouldn't even be able to look and admire them when the equipment is in a rack.
I would like to hear how they are an improvement if any, whether they are dingus modified or non dingus modified. Those who try them please post the results.Home Theater
Mine are being drop shipped to Jesse, to be cryo dingus treated before installing…
