Dust Covers for unused ports
EndersShadow
EndersShadow Posts: 17,719
edited January 2022 in The Clubhouse
First I’d like to thank @Rick88 for sending me down the rabbit hole of covering unused ports :smile:.
Since purchasing some of those Red and White RCA silicone dust covers from him I’ve continued to buy covers for used ports to either try and reduce noise, or just keep them from getting filled with dust.
For my more important gear I bought these RCA covers, as well as these balanced in and balanced out covers.
For my cheaper stuff I still use Ricks covers.
Main reason for this post was to point out some additional covers I stumbled across.
Adafruit sells covers for USB A, also USB C (not linked), Ethernet and HDMI ports. They are stupid cheap so stock up and go wild.
I bought a few packs of each and they work well and blend in nicely.
  • kevhed72
    kevhed72 Posts: 5,157
    Im am counting my unused RCA jacks already to order me some....looks like 28. Thanks!
    VR3 Posts: 29,537
    edited January 2022
    On the hunt for diamond encrusted and cryo treated, quantum charged
    kevhed72 wrote: »
    FWIW I was told these are the Cardas ones just without the branding of course lol…
    pitdogg2 Posts: 27,239
    VR3 wrote: »
    Of course you are.....
  • oldrocker
    oldrocker Posts: 2,590
    Tks, need me some of those..
  • ken brydson
    ken brydson Posts: 9,018
    I've got a good sized baggie of the silicone red and whites that I got from Rick as well. Never got around to using them. Free karma to anyone that wants them.
  • Hermitism
    Hermitism Posts: 4,333
    I'll take them if you let me pay shipping.
  • ken brydson
    Hermitism wrote: »
    PM me your info. Shipping should only be a couple bucks, not worried about that.
  • stevep
    stevep Posts: 360
    So what should you use, RCA condoms or shorting plugs? I'd assume shorting plugs on inputs.
    F1nut Posts: 51,954
    kevhed72 wrote: »
    Those are most definitely not Cardas.
    txcoastal1 Posts: 13,519
    kevhed72 wrote: »
    @F1nut …. They look remarkable close….. but I’m not going to do a ton of research to verify one way or the other lol…
    They work and do what they are supposed to so I got no complaints.
    The XLRs are also quite nice and heavy.
  • kevhed72
    The Cardas ones are 5 bucks a pop on Amazon. Plus I found a guy on the Emotiva forum that will cryo treat them for only an additional 5 bucks a pop. Darnitt.....wonder if I can return my Ebay ones!?!
    kevhed72 wrote: »
    Link to Amazon Cardas ones lol…
  • Hermitism
    Yes, but my covers will have provenance because they were owned by the great Ken Brydson and Rick88.
    @txcoastal1 thise Cardas show as 19.90 + 4.67 shipping…
    I’m trying to find the 5.00 ones @kevhead72 is talking about lol…
    If you divide by 4 = $5... B)
    F1nut Posts: 51,954
    They are similar in design, but not in construction. The ones in your link are an Apollo AV in house design.
    Toolfan66 Posts: 18,162
    edited January 2022
    But is a Cardas @ $5ea. Going to be any better than the Apollo @ $0.80ea ? I don’t really know what the material or construction difference is between the two.
    Edit:
    Apollo is Teflon Nickel Plated..
    Cardas is Billet Brass Nickel Plated..
    So the Cardas would be better built, and definitely feel hefty compared to the Apollo. So the question really is, is there a performance difference or are they just a dust cap??
    Here is a 50pk of Apollo AV for $40
    https://www.ebay.com/itm/400813863894
    mhardy6647 Posts: 35,201
    Nickel plated Teflon...?!?
    edited January 2022
    Here is what I found,
    So it is Nickel Plated Brass as well with Teflon Insulation PTFE..
    Body - nickel plated brass
    Insulation - PTFE (Teflon) for superior noise rejection
    ROHS compliant - yes
    Made in Taiwan
    I went off the description in the ad, my bad.. 😃
    So it makes the price of the Apollo’s look a lot better..
    ahh, Teflon insulation :) That's cool.
    FWIW, while all of these these plugs are nice, in the absence of an electrical connection with the center ("hot") conductor, I don't see how they help with any sort of RFI or other electrical noise rejection. Shorting plugs would, but any of them that are just caps shouldn't short an "RCA" style jack, by design (of the jack).
    kevhed72 wrote: »
    Lmao cryo treated ......
    Yea buddy omg still lmao 🤣😂🤣😂
    F1nut Posts: 51,954
    edited January 2022
    I bought a bunch of Cardas caps a long time ago. They were more like a buck, maybe two each. The Apollo caps weren't available back then.
    I would say they are similar materials and do the same thing.
    Toolfan66 wrote: »
    That’s actually what I bought. Need to buy some more as I ran out.
    Wish they had larger sets of the XLRs
  • pitdogg2 wrote: »
    kevhed72 wrote: »
    If I'm not mistaken, if you send those caps to F1 he will for an additional $5 give it the Royal Dingus treatment (pat.pending)
    edited January 2022
    Toolfan66 wrote: »
    I picked some up for the hell of it, I agree on the XLR's..
    I wonder how many they sold in the last couple days because of this thread. LOL!!
    gudnoyez Posts: 8,174
    edited January 2022
    I got the ones I got from Rick on my Vincent preamp for keeping the dust out, however those Apollo ones for the price might be worth checking out or maybe splurge for the Cardas ones. I also question how they would help with electrical noise, wouldn't even be able to look and admire them when the equipment is in a rack.
    I would like to hear how they are an improvement if any, whether they are dingus modified or non dingus modified. Those who try them please post the results.
    Mine are being drop shipped to Jesse, to be cryo dingus treated before installing…
