Blown RTI-A5 Tweeters!
My mom has been enjoying her system of 2 Polk R50’s being fed from an Onkyo TX8511 stereo receiver for at least 7+ years. About a month ago, both tweeters on the R50’s blew (no sound). I was able to replace those speakers with a pair of RTI-A5’s which was a huge upgrade over the R50’s and played well for a couple weeks. A couple loud playing sessions (volume knob 8/9 o’clock) and I heard crackling from the tweeters.
Today there was no sound at all out of either tweeter. I brought over my Denon 6200 to make sure it’s the speakers and yes it is, same no sound from tweeters hooked up to my AVR (woofers play fine. The jumpers are in place (hopefully correct) and the speakers are single wired. kelaetbottky.jpeg
Would this stereo receiver which is at least 20 years old cause these tweeters to fail? It’s rated 100 watts into 2 channels 8 ohms but recently it has been acting up (no sound switching inputs sometimes). Are there replacement tweeters available? I know it’s a long shot, but would Polk goodwill? What should I look at powering with as a replacement receiver once I get the tweeters replaced so these don’t blow again? I personally have Klispch floorstanders which seems to be easier to drive and I’ve never blown a horn tweeter yet driving to insane levels.
Thanks for any help.
Answers
    F1nut Posts: 51,679
    8 to 9 o'clock on the volume knob isn't normally what one could consider loud. Anyway, the crackling sound indicates the receiver was clipping resulting in either cooked tweeters and/or burn resistors. You should remove the binding post plate where you'll find the crossover attached. The resistors are white ceramic bricks. If discolored or cracked/broken it's bad. Report back.
    F1nut Posts: 51,679
    The tweeter part number is RD0696-1, but IIRC Polk no longer has them.
    VR3 Posts: 29,388
    What f1 said plus I think your receiver is toast
  • I’m sorry I mistyped, I was playing around 1/2 o’clock on the receiver knob and at the time the speakers were bi-wired to the receiver as I didn’t have the jumpers to attach yet. I’m sure this changes things.
    Attached is a pic of the crossover of one of the towers. So I just need new tweeters and a new stereo receiver correct?
    pitdogg2 Posts: 26,934
    If that is supposed to say 1 or 2 o'clock I'd say that your receiver had run out of gas and was sending clipped signals to the speakers.
    tonyb Posts: 33,065
    Yep, sticky fingers on the volume dial kills speakers. Anytime your going into the 10-11 o'clock position or above, your entering the danger zone.. You need to listen carefully and when the music starts sounding distorted, shrill, congested, turn it down....unless you enjoy buying tweeters and crossover parts.
    tonyb Posts: 33,065
    btw, I can't see any damage on those crossovers so count yourself lucky you only need the tweets. You also may not need a new receiver, just better judgement with that volume dial.
  • 1 or 2 o’clock wasn’t really that loud. Had to turn it to 8 or 9 o’clock to really even get any decent volume. Guess the receiver is not strong enough and these rtias are harder to drive and require more power.
    Any tweeters available for source?
    tonyb Posts: 33,065
    Might want to try Parts express, maybe others will chime in with suggestions. Has Polk said when they'll get more in ?
    If your not getting volume out of them, there are other things to look at aside the receiver. Make sure your connections are tight, no plastic from the speaker cable coating is caught under the posts at either end. Make sure the brass connectors are tight also.Make adjustments in the receivers settings. Power wise, your receiver should be fine. Are you using a subwoofer with these ?
    F1nut Posts: 51,679
    The RTiA series are easy to drive, even for a budget receiver. That said, if you are trying to obtain rock concert volume levels you'll need a he-man amp and dedicated pre amp.
    The tweeters are not available new. Check eBay.
