Sda terminal plate sda cable set
VR3
From a build from long ago in a land far away...
Previously owned and mounted but in great shape
Includes 15 Ft sda cable
Plug and play with 5 pin boards
$225 shipped
$225 shipped
Hey Trey,
Not sure which direction I’ll be taking my 2B Studios (stock Pin/Blade from 1989)
Not sure if I’ll TL or not🧐
Are Tony’s @gimpod boards 5 pin?
Forgive my electronic/PCB ignoranceAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
You can easily convert the 3 pin to 5 pin, simply remove the jumpers and install a 5 pin molex... I might have a board mounted connector laying around.
From memory... I believe it is J1 for positive and J2 for negative. You would remove these.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yep have 2 on hand!
If this is still available I’ll take it!
Responded pm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Would they be a direct bolt in for my sda-srs blade blade?
These are sold, sorry for the delay in updates.
This particular set would not work with a SRS first gen but that can be made 😊- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
