WTB dreadnaught For SDA SRS 2
These are blade blade
    pitdogg2 Posts: 27,190
    MW6509 x 4 ? Don't believe it's compatible.
  • pitdogg2 wrote: »
    You are correct, they are four 6509.
    So how can I use them with a non common ground amplifier?
    Sorry I'm a noob.
    edited November 2021
    You cannot, unless you do not use the interconnect cable. Both blades are active and your amp sees a short makes loud noises or lets out the magic smoke. IF The cable is used.
  • pitdogg2 wrote: »
    Looks like I have to contact my amp manufacture to see if I can strap the grounds together right?
    vader540is wrote: »
    Yes
    Another thing to check is resistance/ohms with multimeter between negative binding posts. Remove the speaker eirye from binding posts.
    Too much and it affects negatively.
    I'm sorry I do not remember if it's resistance or ohms, so hopefully someone will chime in.
    Which Amp?
  • pitdogg2 wrote: »
    vader540is wrote: »
    Yes
    Which Amp?
    I have a few
    luxman lv109
    Adcom GFA 555
    NAD 2200
  • agfrost
    agfrost Posts: 2,473
    A single NAD 2200 in stereo mode is common ground. LINK
    I've used a NAD 2600A (largely the same amp) with no problems on my SDA 2B, prior to having my Dreadnaught.
    Edit: That thread isn't exactly confidence inspiring to the max, but I feel it shows that you should be safe with that amp and your speakers. Anyone else care to weigh in?
    Jay
  • agfrost wrote: »
    Awesome! So I have some SDA-2B and I just picked up some SDA SRS 2. iIRC they are the older ones blade/blade.
    Adcom 555 is also common ground.
