Why does the Signa S2 need an HDMI connection in addition to optical?
kwanner
If I'm going to connect the Signa S2 to my TV via an optical cable, why do I still need an HDMI connection as documented in the manual? What capabilities am I getting from that?
Answers
I believe an HDMI ARC connection between TV and soundbar allows a two-way communication between them. Any remote that can operate the TV will also operate the soundbar.
So what if I don't have a free HDMI port, but can run optical. What do I lose? You're saying no volume information goes across optical?
I believe the only difficulty will be that only the supplied remote will operate the soundbar.
but my supplied remote doesn't work. None of the buttons produces response
You should contact Polk at: 1-800-377-7655 for customer support.
I only have one HDMI arc and I don’t believe regular hdmi carries audio
