Part Number for Lsi9 crossover circa 2004
13»
  • VSAT88
    VSAT88 Posts: 1,297
    Hey I am glad to see you back by the way.
  • VSAT88
    VSAT88 Posts: 1,297
    Woops, forgot to post the picture. Bought them like this.
    F1nut Posts: 51,684
    ^ Ouch ^
    VR3 Posts: 29,392
    Thext25 is a compatible tweeter, just swap the faceplate
  • VSAT88
    VSAT88 Posts: 1,297
    No doubt. Kept the inductors, rest went into file 13.
  • caryb
    caryb Posts: 32
    Man, Thanks so much F1. You are the Bomb !
    I need to remember to save a draft before moving to another page (looking at a link)/. I lost a lot of words.
    So replace all Caps And resistors, , Yes ? And the coiled things (induvctors ?), those as well ?...
    So, here is what I gleaned for ordering parts ---->, Yet to be dermined. I did find two tweeterng it s in the states. He wiil not send to mexico, but I have a "mule" comig from the states that could bri
    I see no markings on the inductors, so can you tell me what to order.. ( if you say to replace).
    So`, I see from other , a list of what is needed.
    1 UF, 12Uf, 18 UF x2, 260 UF Sugessted Conilap or Clarity capacitors
    1 ohm/12Watt, 3 ohm 12 watts
    So, If I have a mule in two weeks, I can order in the states and ship to southern Florida..He is a distributor in Cancun for lots o cool stereo stuff .
    So, if you have a store website that you order from, I will contact ,
  • caryb
    caryb Posts: 32
    Vsat... Hi & thanks... Yep swapped L to R tweeters swapped cables . by passed Polk sub... Took tiny tweets out of some old pok Monitoer series two... got a tiny bit of sound on one Lsi , and barely a whisper from the othere. Then put Music through the Series 2 speakers and the crossovers from the series 2 to just my Lsi tweets. Got sound from each ... not strong , but way better that the tweets using Lsi9 x overs.
    Oh Anon.... Yes the the Jumpers were connected all the time, but My Denon did kick off Red blinking light a weelk ago... 3 times in a row... tracked it down to a bad HDMI cable from computer to Denon..
  • VSAT88
    VSAT88 Posts: 1,297
    I use a few different places to order capacitors/resistors/inductors. All depends. I am not affiliated with any of them
    Erse Audio Grade Capacitors
    Parts Connexion
    Sonic Craft
    And not in any order but I will say this. I ain't deaf and I order almost all of my capacitors from Erse. Erse just ain't high end.
    F1nut Posts: 51,684
    caryb wrote: »
    Leave the inductors alone, air cores will be huge and I have no idea of the values.
    Order Sonicaps and Vishay Mills from www.soniccraft.com or Clarity and Vishay Mills from www.partsconnexion.com
    For the 260uF you might find a Solen cap in that value, which will be huge or just stay with the stock ones.
  • VSAT88
    VSAT88 Posts: 1,297
    Used Sonicaps and Clarity as well in the past. As Jessie said these are about the best thing going. Used them is SDA speakers too, that ought tell ya something. They are top notch quality. And those "coiled things'' (Inductors) are best not tampered with if one does not know exactly what one is a doing. So, only reason I came on was to say the same thing Jessie did. lol.
    VR3 Posts: 29,392
    .1MH 0.3 dcr
    1.2MH 0.31 dcr
    9MH 1.6 dcr
  • VSAT88
    VSAT88 Posts: 1,297
    BTW, if you have not figured it out yet I am the rookie, Jessie (F1nut) is the Prez. I learned what I know mostly from reading posts and asking questions just like you are and listening to Jessie and a few others here helping me. Now I can actually be of help sometimes :D
  • VSAT88
    VSAT88 Posts: 1,297
    @VR3 I have read many of your posts and have used so much information that you have provided. I really appreciate it. There goes, said it ! Lol, Thank you.
  • VSAT88
    VSAT88 Posts: 1,297
    @VR3 are you doing x overs still ? If you are then @caryb send them to VR3 !!
  • VSAT88
    VSAT88 Posts: 1,297
    Good lord, feel like a fool now. HA, nothing new. I looked and saw that you were still at it @VR3, apology's . And looks like you never quit.
  • BlueFox
    BlueFox Posts: 15,251
    edited November 2021
    F1nut Posts: 51,684
    VSAT88 wrote: »
    Jesse, no i. Thank you.
  • VSAT88
    VSAT88 Posts: 1,297
    Damn ok . Can I blame that on autocorrect ? Tonight has been a long one. Thanks Jesse.
  • VSAT88
    VSAT88 Posts: 1,297
    If I were honest I would post this and just say that I have not been paying enough attention to what
    I am writing here. Started on the AR-9 crossovers tonight.
    F1nut Posts: 51,684
    Nice speakers!
  • caryb
    caryb Posts: 32
    @VSAT88 Not "Where in Alabama?" , but where in Mexicio is VR3 ?... haha, I will send my crossovers for rebuild . !
  • VSAT88
    VSAT88 Posts: 1,297
    Trey at
    www.version3audio.com
    Or
    www.vr3mods.com
    Is the info I have.
  • VSAT88
    VSAT88 Posts: 1,297
    @caryb just PM me. I really do not know what is going on with the guys that do the x over rebuilds. I am getting conflicting info on the web and the info here is old it seems. I will try and find out. Thanks.
    I would not try those links. Something is wrong with them and send me to pages that do not correspond
  • caryb
    caryb Posts: 32
    vsaT88.. bECAUSE YOUR QUOTE IS "Where in Alabama ?"... I was joking when I asked where Trey was in Mexico... no worries..
  • VSAT88
    VSAT88 Posts: 1,297
    Lol, I got ya. Sending them off is not an option..
    VR3 Posts: 29,392
    I build from scratch so I wouldn't need anything stock...I only ship international thru ebay global shipping so if Mexico qualifies then I could help...
    But email me vr3mods@gmail.com
