Need to clean my outdoor speakers
muncybob
I know using Windex and a lint free cloth is the way to clean speakers that are a bit dusty, but my outdoor ones have grit/dirt around the cone area of the woofer and tweeter. I have neglected to clean them for several years. I'm worried that if I get that area wet and can't remove all the moisture I'll have mud and make matters worse. They actually sound OK as is but the dirt bothers me. Suggestions?
Yep, my name really is Bob.
Definitely don't pressure wash! 😜
I would think a gentle brush and water will go a long way- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I will say that on some speakers (JBL-HLS610's) windex will DESTROY the surrounds. The 610's have a vinyl/rubber like surround on a poly type of speaker cone. It just ate the surround away. Turned it gummy then it just fell apart. I tried to get it off ASAP with plain water but it was WAY too late R.I.P.
Be very careful. -
Sounds like a great excuse to upgrade.
motorstereo wrote: »Sounds like a great excuse to upgrade.
No I had 8 of them for my home theater. I had two spares, problem is my June 25th flood relieved me of all of them as they were on the floor under 16" of water.... Flood took out all my home theater stuff that was in boxes in storage on the floor.
25yrs in this house never any water infiltration. 12" of rain over two days and loss of power in the night for 6 hours. The water (sewage) came up from through floor drains and over the top of the toilet. It never came out of the sump pit until the sewage filled the sump pit.
[img][/img] -
^^^^^ OMG not goodRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
That's horrible.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
No upgrading needed. They still sound great after 20+ years of being outdoors most of each year. I'll just clean the grills up and try to forget the dirt inside.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Use a PH neutral All purpose cleaner duluted at least 10 to 1. Use a Microfiber cloth and spray the cleaner on that and wipe.
Dan
