Need to clean my outdoor speakers
I know using Windex and a lint free cloth is the way to clean speakers that are a bit dusty, but my outdoor ones have grit/dirt around the cone area of the woofer and tweeter. I have neglected to clean them for several years. I'm worried that if I get that area wet and can't remove all the moisture I'll have mud and make matters worse. They actually sound OK as is but the dirt bothers me. Suggestions?
Yep, my name really is Bob.
    VR3 Posts: 29,626
    Definitely don't pressure wash! 😜
    I would think a gentle brush and water will go a long way
    pitdogg2 Posts: 27,539
    I will say that on some speakers (JBL-HLS610's) windex will DESTROY the surrounds. The 610's have a vinyl/rubber like surround on a poly type of speaker cone. It just ate the surround away. Turned it gummy then it just fell apart. I tried to get it off ASAP with plain water but it was WAY too late R.I.P.
    Be very careful.
  • motorstereo
    motorstereo Posts: 2,392
    Sounds like a great excuse to upgrade.
    edited November 2021
    No I had 8 of them for my home theater. I had two spares, problem is my June 25th flood relieved me of all of them as they were on the floor under 16" of water.... Flood took out all my home theater stuff that was in boxes in storage on the floor.
    25yrs in this house never any water infiltration. 12" of rain over two days and loss of power in the night for 6 hours. The water (sewage) came up from through floor drains and over the top of the toilet. It never came out of the sump pit until the sewage filled the sump pit. vrnd4sovmwbj.jpg
    [img][/img]
  • boston1450
    boston1450 Posts: 7,758
    ^^^^^ OMG not good
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Milito
    Milito Posts: 2,003
    That's horrible.
  • muncybob
    muncybob Posts: 3,280
    No upgrading needed. They still sound great after 20+ years of being outdoors most of each year. I'll just clean the grills up and try to forget the dirt inside.
  • mantis
    mantis Posts: 17,607
    Use a PH neutral All purpose cleaner duluted at least 10 to 1. Use a Microfiber cloth and spray the cleaner on that and wipe.
    Dan
