SDA 2B placement
13»
    F1nut Posts: 51,912
    The outgas of curing silicone is acidic/ corrosive. Cured silicone creeps causing contamination issues.
    Silicone contamination is known to have a negative impact on assembly processes such as soldering, adhesive bonding, coating, and wire bonding. In particular, silicone is known to cause de-wetting of materials from surfaces and can result in adhesive failures.
  • rhythm
    rhythm Posts: 60
    Thank you again for the feedback. I’ll be getting back to my speakers soon (have had a house project going on). It’s OK to push on the spiders to check them for cracks, correct?
