New Magico subwoofer
SeleniumFalcon
in Speakers
Thought this might be of interest to our members with deep pockets.
Looks well constructed!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The last subwoofer Magico showed up with at the last Axpona was INTENSE!! It had to of had a 24" driver as it was FREAKING HUGE. I had taken a picture of the raw driver with a bottle of water for reference and the bottle of water looked very dinky next to it. I will state it filled the open auditorium area on the balcony where they had set up and the bass was INSANE!!! It practically knocked you out of your chair 35' away. I'm sure if it was in an average size house your windows would be in jeopardy.
Oh yeah! I'll get two to put in my aircraft hangar system next to my private jet (in my dreams).
@BlueFox your subwoofer has arrived.
Let's start out, I'm not a sub guy. Maybe I'm too old but subs started out as augmentation for bookies and small floor standers that didn't reach low enough. Now all speakers seem to require subs. If my speakers cost anywhere around the cost of this sub, they shouldn't need a sub.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Bingo!
You guys must not listen to electronic music.
Subs are for home theater. Not being a bass-hole I haven't turned my sub on for at least four years. Maybe longer.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
What's a bass-hole?
Does it involve cardboard boxes and duct tape?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'd crappp myself loading the thing in my truck. Would love to hear it thoRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
What's a bass-hole?
A term I made up to describe bass lovers, although it was geared towards those who drive boom-boom cars with the volume at the max.
Do you think this magico would work well in a car audio situation- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A $32,000 sounds about right from a company that offers a $750,00 set of speakers.
The M9
Driver complement:
1.10-inch diamond coated Beryllium tweeter (x1)
6-inch Gen 8 Magico Nano-Tec cone with Aluminum honeycomb core (x1)
11-inch Gen 8 Magico Nano-Tec cones with Aluminum honeycomb core (x2)
15-inch Gen 8 Magico Nano-Tec cones with Aluminum honeycomb core (x2)
Sensitivity: 94 dB
Impedance: 4 ohms
Frequency response: 18 Hz – 50 kHz
Power handling: 20 W (min) to 2000 W (max)
Dimensions:Loudspeaker: 80” H x 40” D x 20” W (203 x 102 x 51 cm)
Crossover: 8” H x 18” D x 20” W (20 x 46 x 51 cm)
Crossover power supply: 8” H x 18” D x 20” W (20 x 46 x 51 cm)
Weight:
Loudspeaker: 1000 pounds (454 kg) each
Crossover: 40 lbs. (18 kg)
Crossover power supply: 60 lbs. (27 kg)
Suggested US Retail Price: $750,000/pair
Ship date: Q4 2020
It’s a lot easier to say you have a million dollar system when you’re at $800K+ before you add cables and componentsA $32,000 sounds about right from a company that offers a $750,00 set of speakers.
The M9
Driver complement:
Sensitivity: 94 dB
Impedance: 4 ohms
Weight:
Ship date: Q4 2020
Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
Discogs -
Aside from expense, the biggest M9 issue is each speaker requires two amplifiers. That's the deal breaker for me.
If Money wasn’t an object I’d still object !"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I'm getting two to augment my my Bose 301's!!!!!If you can't hear a difference, don't waste your money.
Not for me! I have an AVR that has 4 channels!Gustard X26 Pro DAC
There you go! Plenty of amps.
@BlueFox the least you could do is drive the 30 min over to Magico and demo this bad boy!
I've been there a few times. If they release a S7 version 2 then I might go back for a demo, assuming they still do that for a 'low' price purchase. They are getting pretty big now. Maybe I will ask for a comparison between the S7 and the M6. Unfortunately, the M9 are too big for my house.
The Magico S5 speakers I heard at Axpona 2019 were stunning, with great quality bass. I could really get used to listening to those daily!
