Polk Magnifi Max minimum volume too loud on ARC
alwayssunny
I got a new Sony TV with Google Chromecast built in recently. I hooked it up with ARC. I can control the volume with the TV. I used my TV to disable this feature and used the polk remote to adjust volume. Even when I have the volume on the lowest setting +1 (so first volume increment that makes any sound) it's already quite loud.
how can I fix this? My old TV had no ARC so I used 3.5mm jack, so not sure the ins and outs of ARC.
For reference, my TV is:
https://www.bestbuy.ca/order/en-ca/order-details/926055233
Sony 55" 4K UHD HDR LED Google Smart TV (KD55X85J) - 2021
Answers
alwayssunny wrote: »I got a new Sony TV with Google Chromecast built in recently. I hooked it up with ARC. I can control the volume with the TV. I used my TV to disable this feature and used the polk remote to adjust volume. Even when I have the volume on the lowest setting +1 (so first volume increment that makes any sound) it's already quite loud.
Can you control the Polk volume with the tv remote?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
