New Magico subwoofer
Thought this might be of interest to our members with deep pockets.
    VR3 Posts: 29,400
    Looks well constructed!
    pitdogg2 Posts: 26,964
    The last subwoofer Magico showed up with at the last Axpona was INTENSE!! It had to of had a 24" driver as it was FREAKING HUGE. I had taken a picture of the raw driver with a bottle of water for reference and the bottle of water looked very dinky next to it. I will state it filled the open auditorium area on the balcony where they had set up and the bass was INSANE!!! It practically knocked you out of your chair 35' away. I'm sure if it was in an average size house your windows would be in jeopardy.
  • Emlyn
    Emlyn Posts: 4,643
    edited November 2021
    Oh yeah! I'll get two to put in my aircraft hangar system next to my private jet (in my dreams).
    Clipdat Posts: 13,089
    @BlueFox your subwoofer has arrived.
  • marvda1
    marvda1 Posts: 4,941
    Let's start out, I'm not a sub guy. Maybe I'm too old but subs started out as augmentation for bookies and small floor standers that didn't reach low enough. Now all speakers seem to require subs. If my speakers cost anywhere around the cost of this sub, they shouldn't need a sub.
    Puritan PSM156
    You guys must not listen to electronic music.
  • BlueFox
    BlueFox Posts: 15,251
    Subs are for home theater. Not being a bass-hole I haven't turned my sub on for at least four years. Maybe longer.
    What's a bass-hole?
    VR3 Posts: 29,400
    Does it involve cardboard boxes and duct tape?
  • boston1450
    boston1450 Posts: 7,758
    I'd crappp myself loading the thing in my truck. Would love to hear it tho
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • BlueFox
    Clipdat wrote: »
    What's a bass-hole?
    A term I made up to describe bass lovers, although it was geared towards those who drive boom-boom cars with the volume at the max.
    VR3 Posts: 29,400
    Do you think this magico would work well in a car audio situation
  • WLDock
    WLDock Posts: 3,073
    A $32,000 sounds about right from a company that offers a $750,00 set of speakers.
    The M9
    Driver complement:
    1.10-inch diamond coated Beryllium tweeter (x1)
    6-inch Gen 8 Magico Nano-Tec cone with Aluminum honeycomb core (x1)
    11-inch Gen 8 Magico Nano-Tec cones with Aluminum honeycomb core (x2)
    15-inch Gen 8 Magico Nano-Tec cones with Aluminum honeycomb core (x2)
    Sensitivity: 94 dB
    Impedance: 4 ohms
    Frequency response: 18 Hz – 50 kHz
    Power handling: 20 W (min) to 2000 W (max)
    Dimensions:Loudspeaker: 80” H x 40” D x 20” W (203 x 102 x 51 cm)
    Crossover: 8” H x 18” D x 20” W (20 x 46 x 51 cm)
    Crossover power supply: 8” H x 18” D x 20” W (20 x 46 x 51 cm)
    Weight:
    Loudspeaker: 1000 pounds (454 kg) each
    Crossover: 40 lbs. (18 kg)
    Crossover power supply: 60 lbs. (27 kg)
    Suggested US Retail Price: $750,000/pair
    Ship date: Q4 2020
  • displayname
    displayname Posts: 1,204
    WLDock wrote: »
    The M9
    Driver complement:
    Sensitivity: 94 dB
    Impedance: 4 ohms
    Weight:
    Ship date: Q4 2020
    It’s a lot easier to say you have a million dollar system when you’re at $800K+ before you add cables and components :D
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
  • BlueFox
    Aside from expense, the biggest M9 issue is each speaker requires two amplifiers. That's the deal breaker for me. :)
  • If Money wasn’t an object I’d still object !
  • decal
    decal Posts: 3,205
    I'm getting two to augment my my Bose 301's!!!!!
    audioluvr Posts: 5,885
    BlueFox wrote: »
    Not for me! I have an AVR that has 4 channels!
  • maxward
    maxward Posts: 1,677
    There you go! Plenty of amps.
    @BlueFox the least you could do is drive the 30 min over to Magico and demo this bad boy!
  • BlueFox
    Clipdat wrote: »
    I've been there a few times. If they release a S7 version 2 then I might go back for a demo, assuming they still do that for a 'low' price purchase. They are getting pretty big now. Maybe I will ask for a comparison between the S7 and the M6. Unfortunately, the M9 are too big for my house. :)
    The Magico S5 speakers I heard at Axpona 2019 were stunning, with great quality bass. I could really get used to listening to those daily!
