SDA 2B placement
Well if the gaskets behind the drivers and binding post cups look good, I guess the next most likely place (for air leaks) would be the joints around the inside of the cabinet?
Pretty sure I'm hearing an air hiss in the area of the MW's, but if it's from the dust caps I guess there's not much I can do there.
Greg
What' the deal with this spot? Kind of hard to tell from the photo but something definitely isn't 100% normal. It might not be leaking though. Yes it is probably a very good idea to run a healthy fillet of some adhesive of your choice around all inside cabinet joints. There is usually lots of excessive adhesive that may have cracked loose and may not be bonded to the particle board any more. I haven't done my entire cabinets yet. I'm indecisive on whether to cut away the excess or not. I probably will and then will probably run a healthy fillet of JB-Weld all around with a tongue depressor.
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
^^ that is not the original gasket material, looks suspect.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
The gasket material definitely looks original IMO.SDA SRS 2.3TL's
SDA 2B TL's -
Here is original and note the position.
The gasket in question is original.that is not the original gasket material, looks suspect.
You're comparing a driver to the binding post plate.Here is original and note the position.Political Correctness'.........defined
President of Club Polk -
^^^ I see said the blind man, my mistake.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Well, I was kind of hoping I wouldn't need to seal up all of the joints inside the cabinet, but since the gaskets all seem to be in good shape I probably should do just that. I attached a picture of the inside and I'm wondering whether or not I need to scrape off all of the 'goop' that's already there, or if I can just apply something right over it. You can see they really slathered a lot on there in places.
And by the way, what's the preferred sealant for doing this?
Thank you,
Greg
With that much glue in there I seriously doubt there are any air leaks.
Are you pushing and holding the PR in or are you releasing it immediately?Political Correctness'.........defined
I am pushing and holding it in. This weekend I'll try to make a short video of the MW drivers as I do this. Perhaps I'm counting too slowly or something. This way others here can see what I'm seeing and let me know what they think.
I'll double-check the PR gaskets this weekend also. I thought I remember them looking just fine when I removed the crossovers for the overhaul, but double-checking can't hurt. It's been a while.
Thanks,
Greg
Are you testing this by yourself ? If your hearing a leak & you can hear it, you should be able to find this leak with help from extra hands. I see the crossover bolt to mount crossover to cabinet - check that area also. I used LocTite Powergrab on inside of my cabinets just to be positive with great success. You'll find erRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Since you're in there already, no reason to not seal the inside of the cabinet. Peace of mind.
Am I allowed to attach a short video? Doesn't seem to be working.
Thanks,
Greg
Do you hear the hissing sound on just one speaker or both ? If its both you are probably good to go. If just one then there is a snake behind the speaker. OR you do have an air leak in that one.
I hear the air on both speakers. I'm nearly certain it's coming from the dust cap area. The gaskets everywhere seem fine and it looks like there's plenty of glue all around the joints inside so I'm not sure where they'd be leaking. I made a short video of the MW drivers while doing the leak test, but I haven't been able to attach it to a post. I'll keep working on that.
Thank you,
Greg
A few things come to my mind. First, you must have superhuman hearing
2nd you may have a cracked spider and/or dust cap, but to have it on both speakers seems unlikely. More likely to be a cracked spider. The spiders are definitely somewhat porous anyway as are the dust caps but it could just allow more air to escape faster.
Do you have any other MW drivers you could swap in for leakdown testing?George / NJ
iFi nano iDSD DAC
iPurifier3
I definitely don't have superhuman hearing
So maybe I'm not hearing air like I think I am. I definitely hear some kind of hiss where the MW's are, but maybe it's just the sound of the drivers pushing outward? Unfortunately I don't have any other drivers around to swap out.
Here is a link to a quick video I made. Hopefully this is useful. Just wondering if any of you also feel that there's a leak based on the time to recede. The 'clanking' noise as the drivers are pushed out is not the speakers, it's other background noise.
Thanks,
Greg
https://youtu.be/-jyOZFRSrFk
The drivers are receding too quickly. It should take 3 to 5 seconds, yours take about 1.Political Correctness'.........defined
About the excess glue squeeze out, it could still be brittle and cracked in places. I say this because I had my 7B's on the *operating table* many times and the last time I worked on them to put the Rob's Rings in, I leaned a bit too much on the baffle down by the passive hole and heard a definite crack sound (Doofus!). Sure enough there were now cracks in the excess squeeze out visible. I think the adhesive gets very brittle over time. That's when I pulled out the JB Weld and did an emergency repair where I put the stuff right on over the excess and did a fillet all around the lower part of the baffle until I ran out of epoxy. I'll have to do it right some time.
I think you need to seal your cabinet joints as previously suggested.
I watched your vid and my 7B's definitely do not do what yours do, where they initially move back in part way too fast and then seem to hold that position or move very slowly from there until you release the passive at which point the fully retract. Mine are slow and even retraction.George / NJ
iFi nano iDSD DAC
iPurifier3
Thank you very much for the feedback! I'll go ahead and seal up the cabinet joints. I figured I was failing the leak test but I appreciate the confirmation after viewing the video.
I've seen various things suggested for sealing the inside joints: Loctite Power Grab, JB Weld Epoxy, wood glue, etc.
Greg
You want a silicone free caulk type product. Wood glue and epoxy are not good choices.Political Correctness'.........defined
What is the clicking noise when you push the passive in and release it? My 2Bs don't make that noise.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Randy-Maine
by David WMG
I thought the same. Like a bracket inside the cabinet.... I had a loose something on my 2b's years back. Getting old sucks. CRSRandy-Maine
by David WMG
That noise in the background sounds like someone's doing the dishes.SDA SRS 2.3TL's
SDA 2B TL's -
It sure is odd the the clicking sound coincides perfectly with the passive going in and out.
I know, that's why I made the comment about the noise not being the speakers - because the timing is so suspect. I didn't even realize there was something going on in the background until I uploaded the video to YouTube.
I will probably pick up some of this for the inner joints.
https://www.homedepot.com/p/Loctite-Power-Grab-Express-6-fl-oz-All-Purpose-Construction-Adhesive-Squeeze-Tube-2029846/206432100
And I guess while I'm in there I could make some other easy improvements also, such as Dynamat on the baskets and BH5/Sonic Barrier behind the woofers.
Greg
Check the spiders for cracks while you are at it. It may only open up and be visible when the cone is displaced close to the extreme travel limits.George / NJ
iFi nano iDSD DAC
iPurifier3
Why? Will it damage the cabinet over time?
Yep, my name really is Bob.
