Unusual HiFi products from the past.
2456716
  • TroyD
    TroyD Posts: 13,124
    K
    ^ The Dynaquad actually uses the same channel difference information as Polk's SDA uses, however it is applied to surround channel speakers instead of crosstalk cancellation.
    Ken,
    Didn't Polk make a set of rear surround speakers at one point that had dynaquad built in??
  • Polk made an SDA adapter for car systems, I can't remember the model number. But since most car amplifiers have non-common ground outputs it was known as an "amp killer".
  • I used one of these:
  • I wish I still had this:
  • maxward
    maxward Posts: 1,718
    Ahh, The Brick.
  • Jstas
    Jstas Posts: 14,996
    edited October 2021
    It was called the SDA ACM or "SDA Mobile Speaker System"
    ACM stood for Automotive Crossover Matrix.
    The search function here has gone to complete garbage but if you just search for "SDA ACM" you'll find lots of posts about it.
    Found a defunct listing on ebay with good pictures: https://www.ebay.com/itm/254923096420?nma=true&si=lGRlariYYgZRLOJFUhFH2fFzR4Y%3D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
    Expert Moron Extraordinaire
    mhardy6647 Posts: 35,224
    I don't even like wearing normal-looking headphones. ;)
  • invalid
    invalid Posts: 1,525
    The green pen reduces scattered reflections caused by the light from the laser.
    pitdogg2 Posts: 27,293
    invalid wrote: »
    When you shine a flashlight in a mirror where does the light scatter to?
  • invalid
    edited October 2021
    invalid wrote: »
    That's what the manufacturer states. It doesn't really make sense to me, because the pit in the CD is supposed to scatter the red laser light, so a zero shows in the binary code. Sony even released a version called green label sacd.
    invalid wrote: »
    Are you thinking about the SHM-SACD ? Those are made out of different plastic and have a green lacquer back.
    They're even made as a SHM-CD
    Supposedly the clearer plastic substrate allows more laser to dig deeper. The SHM-SACD's I have are FANTASTIC.
  • Nightfall
    Nightfall Posts: 10,083
    The BONE PHONE?!?! LOLOL!
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    edited October 2021
    Tired of the loudness wars? Electronically expand your musics dynamic range!
    afterburnt wrote: »
  • Emlyn
    Emlyn Posts: 4,820
    invalid wrote: »
    I have a few of the SHM-SACDs I ordered direct from Japan. All are excellent sounding and do have the green tint to them. No idea if they sound excellent because they're SHM discs or not. I don't have any of the SHM-CDs but understand that if one rips the CD content to a digital file using the EAC program for error correction or something similar that SHM tech doesn't really do anything different when compared to a regular CD with the same data on it. It's more like an on the fly reading issue with CD or SACD players that the coating and tint is aiming to address. I also remember reading about some new disc technology having the shape of the pits more sharply defined when pressed into the disc.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Nightfall wrote: »
    Problem is that can’t undo the recording itself. Otherwise, doesn’t a volume control and/or equalizer do the same?
  • JayMX
    JayMX Posts: 459
    Nightfall wrote: »
    I have an opportunity to buy one of these and a 14/10 EQ/RTA. Worth picking up?
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • invalid
    gudnoyez Posts: 8,174
    https://www.hifiengine.com/manual_library/sansui/ra-900.shtml
    Had one of these back in the 80s stacked under a sansui graphic equalizer they sure were a thing at the PX while stationed in Germany everyone had one.
    Nightfall wrote: »
    Back in the days when disks made of polyvinyl chloride ruled the earth -- "they" also made "subharmonic bass synthesizers" to recreate the very low frequency bass that was... umm... tricky to cut into rekkid grooves. :#
    there were also... ahhhhmmm... somewhat less elegant, more brute force "solutions" B)
    source: https://www.radioshackcatalogs.com/flipbook/1983_radioshack_catalog.html (pg 54)
  • In my experience the best sounding of the dynamic range enhancers was the Pioneer RG series, licensed from Robert Grodinsky (an under recognized designer). If this was adjusted correctly (meaning not cranked to "11") and used with a good FM tuner (or MP3 nowadays) it sounded good.
    I had a pioneer reverb unit, I'm ashamed to admit. I really stepped off the edge when I traded it in on the Kenwood GE1100 equalizer WITH reverb .....
    I was a bad bad boy.....
    I still have one of those Pioneer reverbs. :#
    (I am not quite sure why...)
    And I'm not surprised one iota
  • I was "this" close to buying an RG Dynamics dynamic range expander for myself, I kept putting it off and missed the boat. His preamp was ahead of its time, cartridge loading built in.
  • The NAD company (Paul DiComo was their first National Sales manager, by the way) offered a uniquely designed turntable. The tone arm was not rigid, rather it would flex slightly to eliminate unwanted tonearm resonances.
    edited October 2021
    The NAD company (Paul DiComo was their first National Sales manager, by the way) ...
    That's interesting. NAD (in the US, that is) in the early days were, if memory serves, in Norwood, MA*, weren't they?
    ______________
    *on the Automile... ;)
  • From an article about Paul:
    "After college at Rutgers, Newark, he moved to Boston, cutting his audio and sales chops first at Waltham Camera and Stereo, then at Tweeter Etc, managing both the Chestnut Hill and Harvard Square locations.
    In 1981, Paul joined the fledgling electronics group NAD as National Sales Manager."
