Marantz (NR 1200), Apple TV and HDR
Just bought and setup a Marantz NR 1200. Set up an Apple TV 4K. In my previous setup, my Apple TV was directly connected to my TV. In the previous setup I could get HDR @ 60MHZ
Now that am running everything thru the Marantz, I am only getting SDR. I have the same issue on my main AVR Marantz SR 5011 in my living room.
Any ideas? All firmware is up to date. HMDI is 4K or 8K rated. Thank you
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
Answers
  • dolbyd
    dolbyd Posts: 430
    Make sure your receiver is in enhanced mode on the Video output.
    Also some TVs need the input settings changed to an enhanced mode. It sometimes is hidden well. It’s set this way to get the energy star rating approved.
    When hooked directly to the tv this mode will sometimes get automatically turned on I have seen this issue before when adding a receiver in the mix.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • Thanks, that helped and I’ve solved my problem.
    Quick note, I switched my Apple TV to the HDMI 1 slot and it automatically went to 4K HDR. My direct box does not need that, so it is fine in HDMI 2 slot. Not sure if the HDMI slots are any different 🤷‍♂️ But it worked
    R: Def Tech
    DVD: Oppo UDP 203
  • rooftop59
    rooftop59 Posts: 7,777
    Kingkwas wrote: »
    Yes apparently many avrs are like that. I had a heck of a time getting my Denon 4200w to pass HDR through the Apple TV, and I finally figured out that the only 2.2 hdr hdmi inputs are the ones next to the outputs. Once I switched, bingo! Would be nice if they would clearly mark the HDR inputs…
    Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply Game Room 5.1.4: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology Power Monitor 900 mains, CLR-3000 center, StudioMonitor 350 surrounds, ProMonitor 800 atmos x4; Sub - Monoprice Monolith 15in THX Ultra Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
