Polk Model 7 Identification
MDN
I'm looking at two different pairs of Model 7's. Can anybody help me ID the tweeters used in each? I believe the second image is of a Peerless, but it's upside down compared to my Model 5's. I appreciate any help, thanks.
Best Answers
SL 2500 a bit better than SL2000
SL2000 can be replaced with RD-0194 much better tweeter.
SL2500 can be replaced with
RD-0198 once again much better tweeter. -
SL2500
In addition to the wrong mid-driver in the second pic of your OP that Peerless looking tweeter is a current production copy. Avoid that pair of speakers.
President of Club Polk -
Thanks for the info. Does the RD-0198-1 tweeter sound as good as the Peerless?
As good or betterHome Theater/2 Channel:
dhsspeakerservice.com/
Answers
The first photo is a SL1000. 2nd one is a Peerless w/o the aperture tuning hole that Polk burned in the dome on later production models. That MW in 2nd photo doesn't look original. Dust cap looks off and should be a silver basket to match what you see in the passive radiator.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
There is no right side up or down for the tweeters I know of.
@Gardenstater is correct that second picture the midwoofer is not Polk.
First picture is sl1000
Second is peerless -
Thanks for the answers. Is the SL2000 tweeter as good as the Peerless?
I'm thinking about adding a pair of Polk 7's to my Model 5's to add more bass. Still undecided though. Any insights are much appreciated. -
Which tweeter is this? Thanks in advance.
Those look like RD0194/8.SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
Absolutely not. Neither of those have the foam ring around the dome.Political Correctness'.........defined
They appear to be SL2500, the tweeters used in Polks Monitor series 2 speakers.
Is the SL2500 tweeter as good as the Peerless? I have a set of Polk Model 5's currently with the Peerless tweeters. My current living area is larger and I need something to help fill in the sound better and add some bass and I was thinking these speakers might work well, but am not sure the SL2500 tweeters would sound as good as the Peerless. Any insights here are much appreciated.
The SL2500 was a cost effective version of the SL3000 Tri-Laminate, with a rubber-like dome. The Peerless was a Silk Dome, far superior. The correct replacement/upgrade for the SL2500, is the RD-0198-1 Tweeter.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I think that the “sound” very subjective to one's own ears. I personally love the peerless and always on the look out for them.M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters -
They are not interchangeable, so a direct comparison is impossible. That said, I'll take a RD0198 equipped Polk over a Peerless equipped Polk.Political Correctness'.........defined
