I want to wax my balls, need help
txcoastal1
They are already clean and shiny, I want to protect them and my playfield.
Do you guys wax your chrome after you polish yours?
I know some of you guys are car cleaning guru's and I would like your input.
This would be for my balls in my pinball machines.
https://ballbaron.com/product/ninja-super-shiny-chrome-pinball-g10/
I never handle the pinballs with bare hands. Always use a cloth and wipe them down every time I clean and wax the playfield. This stops any rust. Wax does not adhere well to the balls, anyway. Extra balls kept in a jar with motor oil, pull one out and wipe it off...rustless after years
^^^You first Lol2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
How much is a new set of balls anyway?
Should balls be regularly waxed for best performance for play?
Or is it best to for balls to have some natural friction, or is it better to have your balls sliding all over the place when banging into bumpers and gates?
Can unwaxed balls damage the playing field over time?
Does the playing field require similar maintenance?
Will the waxed balls be used on multiple playing fields?I disabled signatures. -
TMI on my balls
Freaks!!
I did😳😳😖
I tried waxing my balls but I got second degree burns.Gustard X26 Pro DAC
Ask your wife for help. If she says no kick her to the curb, you need to find someone that has your back. Thick & thin... hairs.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
And not a single moderator in sight.... must be playing a game of pocket pool.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Nothing will make your balls slicker than Renaissance mirco crystalline wax.Political Correctness'.........defined
President of Club Polk -
Learn something new every day. All those years of playing pinball machines and I had no idea of the science behind the scenes of the pinballs.
@txcoastal1 i polish my balls every time I get my hands on them. That is unless I can get the wife to do it.
Normally done every time I take the glass off. I use Novus. This is what the distributor I purchased the machine from recommended. I also use it on the playfield.
2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Currently I am only using the Novus 1 as recommended by the Pinsider's on newer machines then Blitz wax2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Curious as to IF you could use the newer ceramic wax? It seems to be slicker than snot
What an awesome looking table!! -
Maybe on a restore but you have to be careful with products that are to hard and have chemical that may damage the actual clear on a newer table2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I believe that you can continue to use snot on your balls .
That's just a guess, though, I haven't really put a lot of thought into it. 😳Sal Palooza -
My balls always get the white glove treatment. Micro scratches just ruin my game.
Use a bowling ball cleaner/polisher..
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
The Swan Song guy has no Balls…
You going to pick one ☝️ up?
Yes sir, should be here by end of October
...and it's all your fault Todd...more to the story later
https://youtu.be/uQxfCMVRsoA
