Help
boatlover 5254
Ever since I got new Klipsch speakers my system has started to short out after i turn it up a certon amount wat do i do????
Post edited by boatlover 5254 on
Get a better receiver.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
My reciever was doing the same thing. What I would recomend is maybe getting some new speaker wire. It sounds like if you're puting over the amount of Watts your speaker wire can handle over to your speakers then your reciever will act as a circuit breaker and cut it off.-Conor
