Help
boatlover 5254
boatlover 5254 Posts: 18
Ever since I got new Klipsch speakers my system has started to short out after i turn it up a certon amount wat do i do????
    VR3 Posts: 29,762
    edited February 2005
    Get a better receiver.
  • cjoyce
    cjoyce Posts: 11
    My reciever was doing the same thing. What I would recomend is maybe getting some new speaker wire. It sounds like if you're puting over the amount of Watts your speaker wire can handle over to your speakers then your reciever will act as a circuit breaker and cut it off.
    -Conor
