Looking for some Polk SDAs
bored184
Years ago I made the mistake of selling my modified SDA SRS 2s. A move to this day I regret but starting a family and moving required some sacrifices. They were TL modded and sounded fantastic. With the above being said the time has come that I find another set of SDAs. I am looking for a set of Polk SDA 2Bs (wooden tops and fabric side panels), SRS 2 blade / blade, or a set of 2.3TLs. I am located in East Central Indiana and could easy make a fun weekend drive out of it.
I also have a few speakers and amps on the chopping block that I can offer as trade or partial trade.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
If you want SRS 2 then you want the pin/blade model.
I would normally agree but I don't think the pin blade is able to be TL modded. My old set was blade blade and was TL modded.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Pre: Adcom GFP 750, Aikido Tube Pre -
Sending PM
Likely but try and find MW6509 drivers if needed.
Still looking.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Still looking. I have some time off coming up so I good mini vacation might be in order.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Still looking for my dream SDAs.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Oops (deleted)George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I saw but sadly its not local. For my space they may be a bit big, the biggest I can go I think is 2.3TLs.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
If you can do the 2.3's you should be able to do the 1.2's
I have to take WAF into consideration. Right now I have some AR-9LSI in the living and in her mind those are two big.
1.2's are only 8.5" taller....
If only that worked. The Living room is also the where my main setup is so I have to keep her happy when it comes to speakers. I'm extremely fortunate my wife puts up with my hobby but I also try not to push my luck.
Found!Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Found a set of 4th gen SDA 2Bs. Plan is to do the full gambit of mods. Just wish gimpod boards were still available.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
I think I have two sets, if I do we will work something out, I am at work now, I will check latter.. -
PM Incoming!Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
I might have a set of Larry's rings for those, too.
