Looking for some Polk SDAs
bored184
Years ago I made the mistake of selling my modified SDA SRS 2s. A move to this day I regret but starting a family and moving required some sacrifices. They were TL modded and sounded fantastic. With the above being said the time has come that I find another set of SDAs. I am looking for a set of Polk SDA 2Bs (wooden tops and fabric side panels), SRS 2 blade / blade, or a set of 2.3TLs. I am located in East Central Indiana and could easy make a fun weekend drive out of it.
I also have a few speakers and amps on the chopping block that I can offer as trade or partial trade.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
If you want SRS 2 then you want the pin/blade model.
I would normally agree but I don't think the pin blade is able to be TL modded. My old set was blade blade and was TL modded.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Pre: Adcom GFP 750, Aikido Tube Pre -
Sending PM
Likely but try and find MW6509 drivers if needed. -
Still looking.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Still looking. I have some time off coming up so I good mini vacation might be in order.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Still looking for my dream SDAs.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Oops (deleted)George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I saw but sadly its not local. For my space they may be a bit big, the biggest I can go I think is 2.3TLs.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
If you can do the 2.3's you should be able to do the 1.2's
I have to take WAF into consideration. Right now I have some AR-9LSI in the living and in her mind those are two big.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
1.2's are only 8.5" taller....
If only that worked. The Living room is also the where my main setup is so I have to keep her happy when it comes to speakers. I'm extremely fortunate my wife puts up with my hobby but I also try not to push my luck.
Found!Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Found a set of 4th gen SDA 2Bs. Plan is to do the full gambit of mods. Just wish gimpod boards were still available.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
I think I have two sets, if I do we will work something out, I am at work now, I will check latter.. -
PM Incoming!Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
I might have a set of Larry's rings for those, too.
