I want to wax my balls, need help
They are already clean and shiny, I want to protect them and my playfield.
Do you guys wax your chrome after you polish yours?
I know some of you guys are car cleaning guru's and I would like your input.
This would be for my balls in my pinball machines.
https://ballbaron.com/product/ninja-super-shiny-chrome-pinball-g10/
  • NotaSuv
    NotaSuv Posts: 3,871
    I never handle the pinballs with bare hands. Always use a cloth and wipe them down every time I clean and wax the playfield. This stops any rust. Wax does not adhere well to the balls, anyway. Extra balls kept in a jar with motor oil, pull one out and wipe it off...rustless after years
    txcoastal1 Posts: 13,519
    ^^^You first Lol
    msg Posts: 10,465
    edited August 2021
    How much is a new set of balls anyway?
    Should balls be regularly waxed for best performance for play?
    Or is it best to for balls to have some natural friction, or is it better to have your balls sliding all over the place when banging into bumpers and gates?
    Can unwaxed balls damage the playing field over time?
    Does the playing field require similar maintenance?
    Will the waxed balls be used on multiple playing fields?
    msg wrote: »
    TMI on my balls :)
    msg wrote: »
    ask my wife...she owns them
    wife likes a manly man
    a little lube goes along way
    well, you know, we are all getting a little older
    refer to above
    Are you going to pay my lawyer bill?
    edited August 2021
    Freaks!!
    Look whose talking...you peeked at waxing my balls :D
    pitdogg2 Posts: 27,293
    I did😳😳😖
    audioluvr Posts: 5,986
    I tried waxing my balls but I got second degree burns.
  • Nightfall
    Nightfall Posts: 10,083
    Ask your wife for help. If she says no kick her to the curb, you need to find someone that has your back. Thick & thin... hairs. :D
    afterburnt wrote: »
    Village Idiot of Club Polk
    nooshinjohn Posts: 25,996
    And not a single moderator in sight.... must be playing a game of pocket pool.
    F1nut Posts: 51,990
    Nothing will make your balls slicker than Renaissance mirco crystalline wax.
  • motorstereo
    motorstereo Posts: 2,364
    Learn something new every day. All those years of playing pinball machines and I had no idea of the science behind the scenes of the pinballs.
  • tratliff
    tratliff Posts: 1,811
    edited August 2021
    @txcoastal1 i polish my balls every time I get my hands on them. That is unless I can get the wife to do it.
    Normally done every time I take the glass off. I use Novus. This is what the distributor I purchased the machine from recommended. I also use it on the playfield.
    Currently I am only using the Novus 1 as recommended by the Pinsider's on newer machines then Blitz wax
    Curious as to IF you could use the newer ceramic wax? It seems to be slicker than snot
  • Willow
    Willow Posts: 11,253
    tratliff wrote: »
    What an awesome looking table!!
    Maybe on a restore but you have to be careful with products that are to hard and have chemical that may damage the actual clear on a newer table
  • pitdogg2 wrote: »
    I believe that you can continue to use snot on your balls .
    That's just a guess, though, I haven't really put a lot of thought into it. 😳
  • DaveHo
    DaveHo Posts: 3,583
    My balls always get the white glove treatment. Micro scratches just ruin my game.
  • kevhed72
    kevhed72 Posts: 5,160
    edited August 2021
    SCompRacer Posts: 9,121
    Use a bowling ball cleaner/polisher.. :D
    🤤 O.....M.....G......🤤. ,👍👍👍
  • tratliff
    txcoastal1 wrote: »
    You going to pick one ☝️ up?
    Toolfan66 Posts: 18,170
    The Swan Song guy has no Balls…
    edited September 2021
    tratliff wrote: »
    Yes sir, should be here by end of October :) ...and it's all your fault Todd...more to the story later ;)
